Jongbloed 15x10 On Track Car
  • robgoesvroom
    • 821
    #121
    In the garage with a heat gun and fender roller. No cutting! I still have that rubber shit that goes in between the fender lip because I forgot to scrape it off. No fender liner
    • FredK
      • 14761
      #122
      Originally posted by RoccoB517
      I found an amazing deal on 245/40r15 Hoosier R6's that I couldn't pass up. The good news is that I'll try 275's when these are finished, so then we'll have data and everyone can berate each other some more.
      Niice!
      That is a really meaty look.
      Ooh ok, sick!
      • RoccoB517
        • Jul 2013
        • 320
        #123
        Fits on stock body Are you not impressed?
        From where I stand I'm very impressed. I would have needed much hammer to make them fit. The liners in the rear were rusted out badly, so cutting didnt really matter. Fine work!
        sigpicLevel Motorsport: www.levelmotorsport.com
        Instagram: https://www.instagram.com/levelmotorsport/
        Facebook: https://www.facebook.com/LeVelIndustries/?fref=ts
        • robgoesvroom
          • 821
          #124
          Thanks sir, can't wait to see when you get your set all mounted up and tested! The car is sitting much higher than I would like at the moment and I'm not quite sure how much camber I'm running up front, but it's a hoot to drive
          • Wh33lhop
            • 11705
            #125
            Are you maxed out on camber?
            paint sucks
            • robgoesvroom
              • 821
              #126
              No I have more to add. I'm going to get an alignment tomorrow and see where I'm at. Does anyone have recommendations for camber settings with R-comps?
              Will try to make the speedsf event at Buttonwillow next weekend, wh33lhop you should come!
              • Wh33lhop
                • 11705
                #127
                Usually like 3.5 with r comps with .5 less in the rear, if it's adjustable.
                Can't make it but I'm keen on going back to buttonwillow. I drove a lemons race with kronus there once and never went back, it was quite a fun track.
                paint sucks
                • RoccoB517
                  • Jul 2013
                  • 320
                  #128
                  I typically run:
                  Front
                  3.5 camber
                  0 toe
                  9.8 caster
                  Rear
                  2.5 camber
                  1/16 toe in
                  • RoccoB517
                    • Jul 2013
                    • 320
                    #129
                    Spring rates, dampening, and ride height change it a bunch, though.
                    • LJ851
                      • 7918
                      #130
                      I'd love to see a picture down the side of the car showing poke. How much flare do you think it would take to cover the tires? I bet some E46 flares with these wheels would look amazing.
                      Lorin
                      The M30 is God's engine.
                      • robgoesvroom
                        • 821
                        #131
                        car has not yet been corner balanced or aligned. Last time I had an alignment I was at -3* degrees of camber rear: Original rear bushings
                        • RoccoB517
                          • Jul 2013
                          • 320
                          #132
                          I don't think my 245 Hoosiers are stretched that much. I wonder if they are wider than the Maxxis'.
                          • GillesBigCowboy
                            • 507
                            #133
                            This is the ET15 wheel fit with no spacers?
                            87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzit
                            • robgoesvroom
                              • 821
                              #134
                              20mm spacers and 15mm spacers
                              • tinkerputzer
                                • Jun 2008
                                • 508
                                #135
                                What is the actual measured tread width on those 245/15 rc1's?
