Jongbloed 15x10 On Track Car
  • SNEAK413
    • 33
    #151
    Any pics of the side showing the entire car?
    • robgoesvroom
      • 821
      #152
      • GillesBigCowboy
        • 507
        #153
        lap times faster with Hoosiers, or Nittos?
        87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzit
        • HennaE30
          • Apr 2014
          • 1965
          #154
          To your point on the takeoffs, my dad used to use takeoffs on his E46M street/track car (true coils, adjustable camber arms, etc) and he would go through a set in 2 events, on a "relatively" smooth track (as smooth as concrete can be I guess). Tried another full slick? Assuming R6s are similar to NT-01s, and not takeoffs.
          Originally posted by flyboyx
          how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
          Originally posted by Northern
          beer is my new liver cleanse.
          Henna - '84 Hennarot 325e
          Lola - '89 Schwarz 325is - being saved
          Christine - '88 Schwarz 325is - Spec E30 Racecar
          '01 White F150 Lariat 4x4 Supercrew - Daily
          Dad's '05 Interlagosblau M3
          • Wh33lhop
            • 11705
            #155
            Yeah I only used my SM6 takeoffs for 2-3 events before dumping em. Came with 6 heat cycles on em and seemed to fall off pretty quickly.
            paint sucks
            • z31maniac
              • 17566
              #156
              SM7s are supposedly better with heat cycles.
              But if you aren't racing where they are the spec tire, or in a class with a contingency (NASA PT/TT) the purple crack isn't worth it.
              www.gutenparts.com
              • Northern
                I like cupcakes & sh!tboxes
                • 5234
                #157
                @ Rob how close are you to hitting anything on the inside of the wheel/tire in the rear?
                (and what is it?)
                I want to do something similar, but keep the spacer/roll and pull to a minimum in the rear. I have adjustable shock mounts, so I can move that in, and I'll notch the trailing arm if necessary, but I don't know what else is close.
                Originally posted by priapism
                Originally posted by shameson
                • SNEAK413
                  • 33
                  #158
                  Guess I will have to get rid of my bbs decals
                  And as mentioned need a 25mm spacer as a 20 does not fit.
                  • Wh33lhop
                    • 11705
                    #159
                    Bumping this thread for more pics.
                    paint sucks
                    • Eric
                      • 5142
                      #160
                      Good idea!
                      • RoccoB517
                        • Jul 2013
                        • 320
                        #161
                        Like this?
                        sigpicLevel Motorsport: www.levelmotorsport.com
                        Instagram: https://www.instagram.com/levelmotorsport/
                        Facebook: https://www.facebook.com/LeVelIndustries/?fref=ts
                        • Emre
                          • Sep 2007
                          • 1228
                          #162
                          I was looking into those American Racer slicks. Wonder how they compare to Hoosier cantilever slicks?
                          What size are you running?
                          1987 Mercedes 190E 2.3-16: Vintage Racer
                          2010 BMW (E90) 335xi sedan: Grocery Getter
                          • Eric
                            • 5142
                            #163
                            Originally posted by SNEAK413
                            Where can these be purchased?
                            • Jb325is
                              • 2137
                              #164
                              Phils Tire Service- They're cheap too
                              - '88 m54 coupe
                              <3
                              • Wh33lhop
                                • 11705
                                #165
                                Cheap but unfortunately you will also need spacers and extended lugs/studs to run them as they're Miata fitment.
                                paint sucks
