Cant use a 84 E30 for SE30??? and also Pro3???
  • 2mAn
    Señior Mod
    • 20885
    Was just perusing the rule books and both say the cars are 87-91??
    Seriously???:hitler:
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
  • djjerme
    • 5082
    You can.
    Mine started life as an 85 325e. Another buddies started life as an 84 318.
    You just need to swap the M20B25 motor, engine harness and ecu.
    Many have done it, and many more continue to do it as the cost for a good donor shell goes up.
    2016 Ford Flex
    • 2mAn
      Señior Mod
      • 20885
      Is their main concern having a M20B25?
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        Yes m20b25 and the 51mm housings with disc breaks all around those are their main interest
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • Jb325is
          • 2137
          Sure can.. Are you considering building your car?
          - '88 m54 coupe
          <3
          • 2mAn
            Señior Mod
            • 20885
            I have been, but Im not entirely sure what my plan is yet... I know you just did almost the same thing on yours. I would have to gain probably 400# from what Ive read.
            Isnt 2700# the required curb weight?
            Simon
            Current Cars:
            -1966 Lotus Elan
            -1986 German Car
            • Wh33lhop
              • 11705
              2700 with driver, so you'd need to add maybe 100lbs of cage and ballast.
              paint sucks
              • 2mAn
                Señior Mod
                • 20885
                Im pretty sure if I remove the interior and the Lukebox, the car would be down in the ~2350 range, and I'll be (un)lucky to be pushing 200# fully suited and booted.
                Simon
                Current Cars:
                -1966 Lotus Elan
                -1986 German Car
                • ncsubowen
                  • Nov 2013
                  • 1012
                  So ballast yourself appropriately. Get it up on a corner scale and even yourself out.
                  4 doors.. so much room for activities!
                  IG @bluebombr
                  Transaction Feedback:
                  http://www.r3vlimited.com/board/showthread.php?t=323622
                  • Jb325is
                    • 2137
                    Yeah putting weight back in is ideal. Once you get a cage, fire system, m20 stuff, etc back in it you won't be too far off unless you are a tiny little guy.
                    EDIT: kinda forgot your car was an m52 already, but regardless, adding weight is where you want to be so you can place it.
                    - '88 m54 coupe
                    <3
                    • 2mAn
                      Señior Mod
                      • 20885
                      thats what the Lukebox was for! :rofl: I think I will just keep the stereo in the car
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      • TobyB
                        • 5273
                        Not really, because you have to put it in the passenger seat.
                        Many leave the tar in the trunk, run a big battery, etc, until they're sure they need to
                        lose weight.
                        But the early cars do seem to be lighter, just wandering around the paddock.
                        And yes, if you stick a M20B25, wiring harness and struts on, it's Pro3 appropriate.
                        t
                        • Fooshe
                          • Aug 2011
                          • 184
                          You are outside of the Spec E30 rules making that many changes to the car. But the chassis is allowed.
