Koni DA 8611 struts in e30m3 Housings??
  • klodkrawler05
    • Apr 2012
    • 253
    Is anybody on here running this setup? and if so, did you drill a hole through the steering arm/tie rod lever to access the compression adjuster or do you un-bolt the steering arm every time you want to make an adjustment?
    Seems like for at track adjustments it'd be easier to have the 1/2" hole in the bottom that Koni recommends but figured I'd get some other opinions first! Especially since the lever arms seem to be largely NLA at this point.
    -Brad
    My E30: http://www.r3vlimited.com/board/show...50#post3916850
  • klodkrawler05
    • Apr 2012
    • 253
    Bump, nobody on the forum is running Koni double adjustables?
    -Brad
    • TobyB
      • 5298
      not me.
      t
