Hey guys!
its been a while since my last post, i was fabricating...
After a lot of hard work, this babies are ready to roll... I would like to thank Conrad Timms and Julien Violet for the help, without them i would not complete this project.
Front Suspension is based on Early setup, the uprights are made of chromoly steel, wheel bearing is from e28 m5 rears (big bearings) they are easy to change when bad. I had to fabricate the entire hub from scratch, this is because the OEM ones didn't have the proper shaft for the bearing, and if i machined it, it would have very thin wall, and could break.
Rear Suspension is based on Late Setup, the hubs are e30 m3 OEM, i didn't want to use the e28 M5 half shafts because i already had Chromoly HD shafts, that works very good for my HP, so i decided to go OEM on this, but instead of using a circlip to retain the bearing, i used a big hollow bolt to hold it. Camber/Toe parts are DTM replica.
Hope you like this project as much as i love to develop this parts!
My car is being modified at the moment..this are a few pics.
thanks for watching!
