Hankook R-S4
    • 34827
    Might have to give these a try. Running DOT-Rs is fun but the noise and harshness is pretty grating after a while. I like the 225/45, should fit nicely on my 15x7.5's.
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Going to have to grab a set for the slick top when I get new wheels in a month or two
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • Bimmerguy91
        • Jul 2012
        • 982
        I wish they would make them in 225/45/16 :(
        • BlackbirdM3
          • 2764
          Agreed. I'd keep my BBS RKs if they did.
          Will
          '88 BMW M3
          • GThomas
            • Dec 2010
            • 869
            Any e30 reviews of these yet??
            1991 318is S52
            1987 325i Vert
            1991 325i
            2011 e70 X5
            Need Anything E30? -> http://www.gutenparts.com/
            • slums
              • Oct 2016
              • 10
              I have a set in 225/45/17 that I'll be lapping with this summer.
              I've also changed platforms though, so may be hard to tell how the tire feels given it's a new car altogether...
              Forgive me, I used to race a Honda.
              • lcoleman
                • Jan 2009
                • 331
                Early users are saying they grip almost as well as RE71R and Rival S 1.5, but last quite a bit longer. That bodes well, I suspect these tires will be a real winner.
                Still over here waiting on someone to post a 15x9 or 15x10 that doesn't require a massive spacer to fit.
                • e30if
                  • Jun 2013
                  • 12
                  I've got a set of 225/45/15's on my 318is on Konig Hypergram 15x8.5 et25. Have to use a 12mm spacer up front to clear the strut but they fit on the rear with no spacer. I've only got 1 autocross on the tires and it was barely 50 and the tires only had about 100 miles on them so I doubt they were showing completely what they could do. I was impressed on the short time I ran on them though. Unfortunately I don't have experience with any of the recent 200 TW tires on this car, the last set of tires I autocrossed this car on were ancient Starspecs (first gen) and RE-11's.
                  • Shaun K
                    • Apr 2004
                    • 174
                    I'm considering running the exact same wheel/tire setup this summer. Are you on stock struts or coilovers? Would love to see some pics too, if you have them.
                    1989 325is w/M52 swap
                    1989 320i coupe, mostly stock
                    • Wanganstyle
                      • 2828
                      I run R-S3s on my Cayman S and LOVE them. Only negative is that they ride super rough before they warm up but that's not a big deal. Wonder if the R-S4 will outperform the RE-71R?
                      re71r and rs4 are close enough in lap time that its just up to the preference of tire feeling; if you are looking for something to run more laps then a NT01 will still be better; slower lap time though by about a second
                      Advan ad08R will be slower but more forgiving at the limit
                      both Nt01 and re71 last about 11-12 events for me; same car same setup
                      RS4 I will use later; ran rs2 and rs3 and still prefer the breakaway of the bridgestones better
                      cost between NT01, re71r, rs4 are close enough that if you want to get more money out of your track sessions (i.e. go for it entire session); you might as well just go Nt01 unless classing for competition restricts the TW
                      I actually was pondering using RE71R for a 100TW class because its ultimate one lap time will be 1-1.5 seconds than a Nitto Nt01 or Maxxis RC1 (both 100TW). Some friends are doing it with good results. RE71R is actually fantastic in the rain if at full tread; you can run them to the cords like a Nt01
                      • Fooshe
                        • Aug 2011
                        • 184
                        You might feel quicker turn in response with the smaller wallz
                        Not so fast...you might want to stick with the 45's based on the rim size.
                        Remember, side wall flex plays a part in slip angle along with chassis weight and balance. short side walls don't flex much and don't allow for as much roll over, which to a point, is a good thing.
                        Based on what you say you are going to do, go with the 45's.
                        • e30if
                          • Jun 2013
                          • 12
                          I'm running Bilstein Sports with Ireland Engineering Stage 3 springs, and Treehouse racing CAB's. I had to cut a slot into the wheel well plastic at the front to keep the tires from rubbing and I did a slight roll on all the fenders, no rubbing issues that I've found afterwards. I don't have a ton of pictures but this should give you at least a basic idea. Also if anyone is curious the Massive sport brake kit fits in these wheels.
                          Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
                          • Bimmerguy91
                            • Jul 2012
                            • 982
                            I'm just gonna do the RS-4s. Ordering them this weekend.
                            • Wanganstyle
                              • 2828
                              They are good. Very good
                              If you have never hit the limit of a nt01 or re71 then you'll feel the rs4 is amazing.
                              • Bimmerguy91
                                • Jul 2012
                                • 982
                                I would guess I've never hit the limit of my RS-3's so I think the RS-4 will be plenty of tire for me!
