Oil Cooler Opinions
  • squidmaster
    • Aug 2011
    • 2666
    #31
    Post up build quality and everything when you get it
    Sent from my Robin using Tapatalk
    • Digitalwave
      is a poseur
      • 6293
      #32
      I was originally going to mount it behind the kidney, but I don't really want to block my radiator at all. I might cut the slat out of the lower valance and mount it there, as if it were an FMIC. I saw a local E36 M3 that had his mounted like that, then he made a sheet metal duct behind the oil cooler that routed the hot air downwards away from the radiator.
      RISING EDGE
      • FredK
        • 14761
        #33
        I've been using a Setrab 915 for four years now with no issues. I mounted it above a stock cooler that's being used for cooling the power steering fluid. I made a custom bracket using a few pieces of bent sheetmetal and rivet nuts. There are a lot of holes in the radiator support that are already close to or are 10mm in diameter, so it's fairly easy to install some rivet nuts there.
        • squidmaster
          • Aug 2011
          • 2666
          #34
          which bracket are you using to mount it?
          • FredK
            • 14761
            #35
            I used a Setrab bracket to support the bottom of the cooler, and some ones that I folded from sheetmetal for the top of the cooler.
            The Setrab bracket kit is supplied with some rubber isolation blocks, and I'm using them at all four corners.
            • Digitalwave
              is a poseur
              • 6293
              #36
              Thanks for the pic Fred, that looks like a nice setup.
              If I do mount it down behind the valance I will aim for something about as wide as the stock cooler, but 2-2.5x as tall and try and utilize the front valance slats well instead of blocking more of the radiator when mounted behind the kidney.
              RISING EDGE
              • FredK
                • 14761
                #37
                Yeah, back when I got mine, Setrab didn't have their Slimline coolers. The widest Slimline coolers look great, and are probably just about the same width as a stock cooler.
                It'd be a good idea to put some screening in front of the cooler to protect it from track debris like gravel or rubber.
                • Digitalwave
                  is a poseur
                  • 6293
                  #38
                  Good idea and good info. I'll keep the thread up to date as I progress with the oil cooler. It'll be a couple weeks until I order everything, as the car is in the shop getting the roll bar built right now.
                  RISING EDGE
