New 15x8 wheel coming!
  • dlmrun2002
    • Apr 2007
    • 808
    #361
    I'd take a set for this years track. is it worth putting 15 x 8 in the rear with 15 x 7 in the front or could you go 15 x 7 all around?
    dlm
    • kishg
      • Sep 2006
      • 2624
      #362
      dlm
      on an e30 i'd go 15 x 7 all around.
      '12 F30 328i Sport Line
      '91 SpecE30 #523
      '00 Ford F-350 Dually Tow Vehicle
      BMWCCA #360858 NASA #
      128290
      • bwh13
        • Jan 2007
        • 437
        #363
        Ordered 1 15x8 today...
        Will test it on my 88 325is with the 11.75" 4 piston kit I designed for it. Will also test with the 11" kit as soon as I get the brackets made...
        • Jean
          • 18228
          #364
          What's the reason?
          I'v got 225/50/15 v710 tires waiting for wheels. I am looking at going with 15x8 all the way around. Suspension will be fairly stiff at around 700f/900r and -3 front camber.
          • JGood
            • Jan 2004
            • 7959
            #365
            Originally posted by Jean
            What's the reason?
            I think it would fit a 7" just fine as Tire Rack measures a 225/50/15 V710 on a 7" rim (range is 6"-8"), so it would be extra weight for no reason.
            e30 restoration and V8 swap
            24 Hours of Lemons e30 build
            • hoyabmw
              • Dec 2006
              • 207
              #366
              It fits, but you'll get more contact patch on an 8". On the 7" it's very pulled in. I used to run 225 710s on 7" wheels before I went to 275s, and I was looking for an 8" wheel. These are light enough that you're definitely better off with the 8".
              • kishg
                • Sep 2006
                • 2624
                #367
                15 x 8 is not spec e30 legal..
                '91 SpecE30 #523
                128290
                • Jean
                  • 18228
                  #368
                  Oh that, no care about spec e30 ;)
                  • JGood
                    • Jan 2004
                    • 7959
                    #369
                    I can believe it, I ran 225's on a 6.5" and it was pulled in pretty bad.
                    Now I'm running 205's on an 8 and it's stretched like a dubber :(
                    • Massive Lee
                      • Sep 2006
                      • 6782
                      #370
                      8" wheels would be great with 225 rubber.
                      massivebrakes.com
                      • kishg
                        • Sep 2006
                        • 2624
                        #371
                        depends on the tire. toyo-r888 225/50/15s would fit perfectly on 15 x 7s
                        '91 SpecE30 #523
                        128290
                        • 2002maniac
                          • 4260
                          #372
                          unless you are required by the rules to run 7" wide wheels, 15x8's would be better.
                          I've run 225/45/15 hoosiers on both 7" and 8" wheels and they fit much better on the 8's
                          • 2002maniac
                            • 4260
                            #373
                            why not go wider though? The toyo would still be bulging, and would fit better on an 8
                            • kishg
                              • Sep 2006
                              • 2624
                              #374
                              you missed the part about 15 x 8 not being spec e30 legal. also i don't think the toyo would bulge as much as the hoho.
                              '91 SpecE30 #523
                              128290
                              • 2002maniac
                                • 4260
                                #375
                                225's are legal?
