R-compound tire recommendation?
  • bimmer freaks
    • Jun 2006
    • 43
    I have 15X7 Team Dynamic rims and was wondering what size r-compound tire will fit? I was hoping to squeeze on some 225/50/15 hoosiers, but was not sure if they would clear. Also what's better - 225/45/15 or 225/50/15 or go with 205/50/15? Any opinions are welcome. This will be for an autox car. How about a staggered setup? Thanks.
  • JGood
    • Jan 2004
    • 7959
    Everyone says to stay away from staggered, but ever since I went from 225/50/14 rear & 205/55/14 front to 205/55/14 all around, I get more inside-rear wheel spin on autox courses. It didn't seem to make the car push any more with wider rears either.
    This was with V710's.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • joshh
      • Aug 2004
      • 6195
      An 8" wheel would obviously be better but there's nothing wrong with putting a 225 50 15 on a 7". And I would go with the 225 for sure. 710's last way longer than Hoosiers so I'd also go with those.
      I'll be trying a staggered set up this year but on my Integra and the opposite of the wides in the rear.
      "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
      ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
      • bimmer freaks
        • Jun 2006
        • 43
        thanks
        Thanks for the opinions...JGood, do you have an open diff or LSD? I am really considering 225's in the rear and 205's up front. I am running IE3's and billy sports on Azenas right not and it is ok. The azenas are getting worn and will need replacement in the future....I just am dying to try out some r-comp tires...so you guys like th 710's....hmmm, I had my heart set on the hoosiers, but might reconsider...thanks again.
        • joshh
          • Aug 2004
          • 6195
          If you have the money get the Hoosiers. But expect anywhere from 20-70 runs on them before they wear out. No joke.
          A local member hear corded a set of Hoosiers in one day with his EVO.
          The Hoosier has awesome turn in but will let go very quickly if you get the tire past their grip level.
          The 710's are great because they are as predictable as a very good street tire yet they last 2-3 times longer than the Hoosier. The 710's don't have quiet as much overall grip but are just as good or better in other ways. Let alone cheaper.
          • Bruce Colby
            • Oct 2007
            • 30
            I have a couple comments but no real answer to your question. If you put on tires with a lot of grip, you'll generate a more body roll in the corners, more dive on braking and more squat on acceleration, than you had using tires with less grip. If you get a lot of lean/dive/squat, the contact patch will become less than optimal. You may be able to make camber changes as a workaround for cornering but you can only go so far in the front before you'll start to mess up your braking. And if you have a lot of power, too much negative camber in the rear will impact traction on acceleration. Stiffer sway bars will help control roll; stiffer springs will help control roll, dive and squat. Stiffer springs may also mean you need to alter the damping (shocks) if you want to avoid bouncing around and losing traction. It's can be a vicious/expensive circle.
            You also need to consider what you are doing. AutoX needs tires which are consistent from run to run. Track tires require a significant workout in order to get warmed up to the point where they work properly. Consequently track tires tend to change a lot from run to run at autox's so they may not be your best bet. Something like a Toyo RA1 or the very similar Nitto NT01, might be a good compromise. There are some very sticky/soft tires, Hoosier makes some and so does Kuhmo which might be better for autox but it might depend on how close together your runs are.
            Big tires are not always the best tires. Bigger tires are heavier than small ones so they add rotational mass and this reduces acceleration (and deceleration). Bigger and/or wider rims tend to do the same thing. If you have enough torque to spin up heavier tires/wheels and enough brake to slow them down, go for it. But remember that the rubber needs to stay properly planted on the the road surface in order to work effectively.
            Heavier tire/rims also increase unsprung weight. A big increase in unsprung weight can have an pretty nasty impact on your car's handling if the course is bumpy.
            In a perfect world, more/stickier rubber would always mean faster times but it doesn't work that way. It's all about finding the right compromise.
            • alex
              • 2024
              Go same size as you will be able to rotate tires for longer life.
              I'd get 225/50 for your setup.
              Alex.
              • markseven
                • Sep 2006
                • 5327
                This is really good info.
                I Timothy 2:1-2
                • Jeremiel5
                  • Jan 2008
                  • 735
                  +1923419485207987520398752, thanks for the info! :D
                  • Jean
                    • 18228
                    +1 and another 1+ on the tire rotation issue.
                    There is also another good AutoX dot R tire out there now, lots of guys trying it out, BFG r1.
                    • Lance Racing
                      • Jul 2005
                      • 2340
                      I agree...
                      same size to maximize tire life.
                      Will you be shaving the tire? Shaved vs. unshaved makes a big difference in adhesion. I would think hard core Auto-Xers are shaving to 2/32.
                      I run 225-50-14 on my race car and run great. I think there are better Auto-X tires than a Toyo RA1. I run the RA1 on the race car, but that is on a road course for 30 minute sessions and they do take a lap to warm up. I shave to 4/32 for a dry track. I keep another set of full treads for a rainy track.
                      Lance Richert '88 M3, #35 PRO3, i3 etc.
                      www.LanceRichertArchitect.com
                      2019 E30 Picnic Weekend: June 22-23 2019
                      • bimmer freaks
                        • Jun 2006
                        • 43
                        thanks for the replies.....I am leaning towards 225's all around. Not sure what tire to get yet. I am in south florida where the pavement gets very hot, but I think I may go with a used set of A6's or the kuhmos...thanks
                        • alex
                          • 2024
                          IBig tires are not always the best tires. Bigger tires are heavier than small ones so they add rotational mass and this reduces acceleration (and deceleration). Bigger and/or wider rims tend to do the same thing. If you have enough torque to spin up heavier tires/wheels and enough brake to slow them down, go for it. But remember that the rubber needs to stay properly planted on the the road surface in order to work effectively.
                          Also consider change in overall diameter and consequent effect on max speed and acceleration, especially if diff choices are limited.
                          • tdfox
                            • Apr 2008
                            • 14
                            yeah really Great info Thanks
                            • Fair!
                              • Mar 2007
                              • 202
                              +1 to all of this.
                              We ran 225/50/15 Hankook Z212 (9.2" of section width!) on a 15x7" wheel on our E30 and it cleared with room everywhere, no fender rolling. We were limited to a 7.5" wide wheel for this class (STS) but ony found affordable/light 15x7 options as the time. It "worked" and still made skidpad numbers that humilitated many R compound competitors...
                              Terry Fair - www.vorshlag.com
                              Project Thread for the now-burned-to-a-crisp $2011 GRM Challenge Winning E30 V8 :(
