Originally posted by Joe318is
View Post
9lb Magnesium Wheel
Originally posted by markseven View PostEMPI. That's a blast from the past! I had a '63 Notch and a '64 Square :D EMPI wide pattern Porsche alloys on the Notch and 8-spoke on the Square.
I think the centerline style would limit brake cooling and heat up the wheel bearing and wheel bearing grease.
we ran a similar set up on our road race karmann ghia with ERCO's and 4 lug porsche brakes all around. even in the enduro races we had no problems.
i will see if i can dig up some pics of the ERCO's on the bug and scan them.seien Sie größer, als Sie erscheinen
Originally posted by der affe View Postas far as the cooling, that is why i went with the ERCO's and had him drill 5 x 1-3/8th" holes in each wheel. i was running porsche 356 front brakes and then switched to wilwood front discs and no cooling issues.
i will see if i can dig up some pics of the ERCO's on the bug and scan them.I Timothy 2:1-2
Originally posted by makaio View PostAnd actually it is not flammable. It is a combustible metal.
At the end of the day, if you ever have to deal with a magnesium fire you're probably not going to care whether you call it "flammable" or a "combustible metal"...
Originally posted by z31maniac View PostIf you're in a position where you're looking for that last 1/10th of a second maybe.
I watched my friend who races motorcycles, and whose dad is a former AMA champ, and sometimes Mg wheels would get bent and destroyed just going off track, not even wrecking, just riding in the pot marked ground.
And they were screwed up in wrecks.
I'd stay with a lightweight, cheaper yet still strong forged aluminum wheel.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
I think with wheels like that it would either bit hit or miss. BBS and Dymag are some of the only companies that have made good wheels out of magnesium and they are really, really expensive.
A good example are the OEM CSL wheels made by BBS, which were entirely magnesium alloy and cost somewhere around $6000+ if you can find them. And then there are the Dymag magnesium and carbon fiber wheels which go for a similar price and are a little easier to come by.
But either way, magnesium is really light, but very reactive and soft making it very difficult to properly alloy it and manufacture it. Get the manufacturing and alloy percentages wrong and they bend on the first small pothole you hit.
For the value and strength, forged aluminum wheels are so much better. Half the price of the magnesium wheels and much stronger. I had a Toyota 4-runner plow into my car right at the rear wheel and the BBS RG-R wheel on my car was straight with the exception of a tear in the lip. In contrast, that collision tore the entire wheel off the SUV.
Originally posted by mkodama View PostA good example are the OEM CSL wheels made by BBS, which were entirely magnesium alloy and cost somewhere around $6000+ if you can find them.
Also, list price on them is $611.01 for the front, and $638.91 for the rear.
M3 CSL Wheels
8.5" front- 36-11-2-282-650
9.5" rear - 36-11-2-282-999
M3 Comp Package Wheels
8.0" front- 36-11-2-282-895
As you can see, the wheel part number is the same for the rear 9.5 wheels. They are not Magnesium. And certainly not $6,000.00!
Originally posted by jblack View PostDon't know where you read that - but the E46 M3 CSL wheels were Aluminum. They are available in the US on the M3 on the Competition Package (in a slightly different size for the fronts).
M3 CSL Wheels
I was confused after reading an article where magnesium wheels were mentioned on a CSL. As well as lots of damn online rumors.
Adding to the confusion, BBS does make magnesium wheels that look very similar to CSL wheels at $1600 a piece:
