New dead pedal
  • Massive Lee
    • Sep 2006
    • 6785
    New dead pedal
    Hi guys. I just posted in the classifieds section about a new dead pedal I am producing for e30 track cars. The dead pedal's angle is currently 15 degrees but it can be adapted to everyone's taste.
    Dead pedal is made from laser cut stainless steel and is CNC folded. Comes with stainless domed bolts.
    massivebrakes.com
  • kishg
    • Sep 2006
    • 2624
    definitely interested lee.
    '12 F30 328i Sport Line
    '91 SpecE30 #523
    '00 Ford F-350 Dually Tow Vehicle
    BMWCCA #360858 NASA #
    128290
    • Eric
      • 5142
      I want one, it's wierd to have no carpet and no dead pedal
      • Massive Lee
        • Sep 2006
        • 6785
        Indeed, the soft foam padding acting as a dead pedal works fine on the stock carpeting. Remove it, and then suddenly the driver feels... naked.
        Lee
        massivebrakes.com
        • kishg
          • Sep 2006
          • 2624
          just got this in the mail. very nice. feels very sturdy and the finish is great. can't wait to install it.
          '91 SpecE30 #523
          128290
          • Massive Lee
            • Sep 2006
            • 6785
            Here's the non-carpeted unit. It bolts to the curved part of the firewall (rear of wheel well). A new version will be available for carpeted cars, next week.
            Picture of the race unit - not carpeted shell.
            massivebrakes.com
            • gearheadE30
              • Jun 2007
              • 3734
              Got an approximate price on the one for cars retaining their carpet? I am very interested.
              Project M42 Turbo
              • Massive Lee
                • Sep 2006
                • 6785
                Should be priced the same for the Hartge-style, and a bit more for the M-Technic style as there are more folds and more metal surface.
                massivebrakes.com
                • Ray Smoodiver
                  • Jun 2004
                  • 8809
                  LHD only?
                  • Massive Lee
                    • Sep 2006
                    • 6785
                    Hi Ray
                    The four dead pedals are designed for LHD cars. But I am pretty sure that one of them will fit a RHD. The Hartge-style should fit a RHD as it is designed to fit over the mushy foam foot rest. It should be ready in a week.
                    massivebrakes.com
                    • Dave
                      E30 RAT
                      • 11675
                      Lee,
                      When you get some pics of the non-carpeted one installed, post them up.
                      I want to see where this is in relation to the clutch pedal.
                      Current Cars
                      2014 M235i
                      2009 R56 Cooper S
                      1998 M3
                      1997 M3
                      • Massive Lee
                        • Sep 2006
                        • 6785
                        I will ask people to post some pictures when their unit is installed.
                        massivebrakes.com
                        • Dyno4mance
                          • 345
                          Do you think it would fit mine with the cage blocks?
                          2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
                          • Massive Lee
                            • Sep 2006
                            • 6785
                            Hi there.
                            The pedal is 3-1/4" x 9-1/2" and should fit properly between the forward tubes and the clutch pedal, but make your own tests by mocking up a rectangle of paper. The base of the dead pedal will be bolted ahead of the block, and you will have to cut some of that diamond plate, and also maybe remove/cut one of the two upper mounting tabs on the dead pedal to fit around the plate on the firewall. But removing one of the tab is one of reasons why they are separated.
                            That being said, and I would hate to criticize your cage builder but I doubt that your cage will pass inspection (at least with BMWCCA CR) as the electrical loom should not be going between the rocker and the block. If you have an accident, it will crush the wires and risk electrical fire.
                            massivebrakes.com
                            • Dyno4mance
                              • 345
                              Thanks for the feedback I will measure tonight
                              It is strange that you say that about the wiring harness....the cage builder I used builds a great deal of the cages for the NASA spec e30 series in the SE...That is how I found him as a few of the racers have used my shop facilities for dyno work and the cage was just replicated and I assume they all have log books...
