Roll Cage Sources Post em Up
  • DCColegrove
    • 2748
    Originally posted by moatilliatta
    then sent to taiwan and and bent to spec, sent back for roll cages on the dollar.
    And the first 3 or 4 you get will be fine but then...
    I could go on and on.
    • kishg
      • Sep 2006
      • 2624
      there are already several weld in kits available. quite a few spec e30 guys have the evil genius kit as shown here: http://www.evilgeniusracing.com/Spec...ecE30Cage.html
      '12 F30 328i Sport Line
      '91 SpecE30 #523
      '00 Ford F-350 Dually Tow Vehicle
      BMWCCA #360858 NASA #
      128290
      • DCColegrove
        • 2748
        Are there any kits available that you know of that don't exit the monocoque?
        • JGood
          • Jan 2004
          • 7959
          Wow, that looks really good. Do you happen to know how much that kit sells for?
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • Massive Lee
            • Sep 2006
            • 6785
            Originally posted by Massive Lee
            Actually, a good business would be to sell a weld in cage... in kit. Let me explain. The most difficult part in building a cage is the actual design and the prototyping. In fact, most cages are one-off prototypes. It is a very time consuming process.
            So, if somebody comes up with a great design, with every single piece already cut up and notched, and only needing to be welded together, then it would be a bargain for the consumer.
            I hope I haven't said anything that would deserve me a ban... :dot:
            massivebrakes.com
            • kishg
              • Sep 2006
              • 2624
              i heard approx $1050.
              '91 SpecE30 #523
              128290
              • BMWLA
                • Jul 2008
                • 407
                Holy crap!
                • JGood
                  • Jan 2004
                  • 7959
                  Wow, that's not bad! It comes all pre-bent and pre-cut? With mounting plates?
                  • kishg
                    • Sep 2006
                    • 2624
                    yes. although you probably need to measure and modify a little to fit as with any kit. i heard the kirk kit is very similar too and priced similarly.
                    '91 SpecE30 #523
                    128290
                    • PaintPro21
                      • 660
                      TC Design did a custom well in roll bar for my M and it was 1k for everything. When you factor in labor and that it's all one piece with strong floor plates, I think it's cheaper then a bolt in kit.
                      ApexRaceParts.com - Facebook - Twitter
                      • BMWLA
                        • Jul 2008
                        • 407
                        Anything else out there besides AutoPower and VSR for bolt in?
                        • dirty30
                          • 3123
                          It looks like autopower has reduced the size of its base plates to accomodate stock shoulder belt mounting. Has anyone made their own plates and welded them in using an autopower kit?
                          • deutschman
                            • May 2008
                            • 5958
                            how much can one expect to pay some one to weld the cage in for you if you buy a weld in kit? i have a friend that can weld but i have seen his work and frankly it sucks.
                            • kishg
                              • Sep 2006
                              • 2624
                              i wouldn't do bolt in. if your doing a kit, weld in is the way to go.
                              '91 SpecE30 #523
                              128290
                              • Guy_Fawkes
                                • 18
                                Safety Devices out of England makes kit bolt in and weld in cages. Northstar Motorsports imports and sells them here in the US. Bit more expensive than the Kirk or Evilgenius kits.
                                Northstar Motorsports, Auto Racing Safety Equipment, Helmets, Suits, Seats, Harnesses, Hans, Brakes from top manufacturers including Alpinestars, Arai, Bell, Hans, OMP, Pagid, Schroth, Sparco
                                Safety Devices has been designing and manufacturing roll cages (Roll Over Protection) for over 50 years.  In fact our subsidiary, Aley Bars, has been making motorsport roll cages since the mid 1960’s when John Aley introduced the first roll cages to European motorsport.
