Oil pan is destroyed - anyone have an engine support?
  • graphikg
    • Jan 2008
    • 1614
    My oil pan has been destroyed by the love of coilovers.
    I need to swap it out and was wondering who has an engine support beam that goes across the motor over the fenders for me to swap it out. I just need to borrow it. Thanks all.
  • travish325
    • Jun 2012
    • 1151
    Why? Its easy to just undo mounts and jack the motor up. I have changed many that way only takes 30-45 minutes if that
    • mcr_driver
      • 4491
      what he said
      • graphikg
        • Jan 2008
        • 1614
        Forgot to add that I have a swapped motor - s50. There's no way to do a 45 min oil pan swap on a 24v right? Should the process be the same? Luckily my Gettrag 260 bell housing has holes drilled in it to get to the last two long oil pan bolts.
        • dashboardmonkey
          FUCK YOUR WAFFLES
          • Jun 2008
          • 6158
          The flywheel is what gets in the way. IIRC.
          -Andy
          • e30shmobberr
            • 1934
            skid plate man!
            Patrick - IG:niicknac
            RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
            • mkcman17
              • Jul 2010
              • 8240
              i don't think it's possible to properly do an oilpan in thirty minutes by any stretch of the imagination. but yes, you should be able to lift the motor enough without a crane support.
              1989 LN106 Hilux / 3.0TD SFA
              1974 2002tii / stock
              2002 IS300 / 5spd LSD
              • ethrtyiS
                • 8147
                this is your friend:
                http://www.harborfreight.com/automot...own-47764.html
                「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
                「my feedback thread」
                • graphikg
                  • Jan 2008
                  • 1614
                  ^^^ Ok, where do I hook those up on the body to suspend the engine? That is going to be scary; lying under the engine supported by a strap.
                  And if I tried jacking up the engine, where is there a good support point?
                  Before this car touches the ground again, I am getting a skid plate on there for sure. - shmobber, what plate do you have?
                  • Cabriolet
                    • 9620
                    I have an M20 skidplate from EJknight. never installed. (raised my car back up). cost-10%
                    Much wow
                    I hate 4 doors
                    • ethrtyiS
                      • 8147
                      around the shock towers and under the fan clutch on the front. the straps can hold up to 800lbs or something like that so it's perfectly safe as long as you have it strapped right. makes the job much quicker.
                      he's got a swap.
                      • Cabriolet
                        • 9620
                        Originally posted by ethrtyiS
                        he's got a swap.
                        reading, tell me how it works =P my bad...
                        there are a ton of guys on r3v selling all styles of skid plates. i really like EJ's but it's just pref.
                        as for holding the engine up. i held my entire VWcabriolet from my dad's rafters when doing a clutch job. wasnt smart but worked. I have a crane now, so if u want to bring the car over next weekend ill help you change the pan. est 1-1.5h
                        Much wow
                        I hate 4 doors
                        • graphikg
                          • Jan 2008
                          • 1614
                          So, to put the strap around the shock towers, I am guessing that I have to take out the front shocks and springs. Or atleaest loosening up the shock from the Camber plates and drop the sway link to slip the strap through. Is this the right idea?
                          That would be great!!! I would gladly take the help and youre close anyway. I think we have even met on one of the friday drives to the Stoneridge Pleasanton meet. I however cant drive the car cuz of the pan. Anyway to bring the crane over and do it in my garage? I have a touring to transport the crane.
                          • ethrtyiS
                            • 8147
                            no, no. you just wrap it around the shock towers. no need to unbolt anything but the motor mounts.
                            • mkcman17
                              • Jul 2010
                              • 8240
                              Undo the 17mm nuts and jack from a/c compressor. Some people here won't like that, but it works. You don't need to lift it that much.
