Bay Area: looking for help installing front springs
  • freeride53
    • 11972
    Hey guys - looking for some help in installing my front springs in the Bay Area.
    Located in the East Bay but willing to drive around the Bay!
    -S
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • BlackbirdM3
    • 2772
    Its pretty easy, might take an hour to do at most. I'd offer to help but I don't have anyplace to work. Remove the brake sensors, the brake calipers, unbolt the control arm from the strut, remove the strut from the body, remove the big nut from the strut mount. Lift mount off, remove springs, reinstall in reverse order. The only thing you might need is a spring compressor, but not necessarily.
    Will
    '88 BMW M3
    • Thizzelle
      • 4422
      I don't know where everyone gets there time from. Takes an hour if you have a lift and everything goes smoothly minus cleanup and locating tools.
      This shit will take 4 hours
      "I wanna see da boat movie"
      "I got a tree on my house"
      • Cabriolet
        • 9620
        Thizzelle, if you do it the cheating way it takes about an hour, if they arent stock springs to start. the stock ones need to be compressed a lot to get them out
        Much wow
        I hate 4 doors
        • 2mAn
          Señior Mod
          • 20991
          I cheated and didnt even take off any of the brake stuff. Pretty easy with aftermarket springs. Hardest part for me is the nut on the top of the strut
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • RUFFLZ
            • Apr 2011
            • 3122
            Originally posted by 2mAn
            Hardest part for me is the nut.
            • BlackbirdM3
              • 2772
              There are 12 bolts that need to be removed. (at least on an M3). 4 that hold the control arm to the strut, 3 that hold the strut mount to the car, 2 that hold the brake caliper to the strut, 1 that holds the swaybar onto the strut, one that holds the damper and springs to the hat, one that holds the ABS sensor in place. Oh, I wasn't counting pulling the wheels, but there are 5 more bolts to be removed. Break the wheel bolts lose, jack the car up, unload the swaybar, remove the nut, remove the bolts for the brakes, and ABS sensor, remove the 4 bolts that hold the control arm to the strut. Remove the 3 bolts that hold the strut to the car. Remove strut, then depending on the springs use the spring compressors to unload the spring hat, remove the nut from the top of the damper releasing the hat and spring. Remove, replace, reinstall in reverse order. I think it requires perhaps 5 wrenches total. I've done it several times with my M3. It might take two hrs if things haven't been removed in the past 25 years.
              Its not a hard job to do.
              Will
              '88 BMW M3
              • DDKing13
                • Aug 2014
                • 144
                Originally posted by RUFFLZ
                I lol'ed :giggle:
                Build Thread
                • freeride53
                  • 11972
                  One More thing to note - I'm swapping my Eibach Pro Kit springs to H&R Races from an M3.
                  ...not that much difference in spring travel, from what I've gathered...
                  I lack tools, space, and know how.
                  My grandpa who did the fronts for me in high school passed away two months ago.
                  I did the rears (easy part).
                  • Cabriolet
                    • 9620
                    all you need is a jack and a 17mm deep socket and to do this job
                    Much wow
                    I hate 4 doors
                    • freeride53
                      • 11972
                      wanna help a brother out? haha
                      • golde30
                        • 11464
                        Will
                        Non M e30s don't have the 4 10mm bolts on the bottom of the strut housing. Instead thats all 1pc, so you have to pop off all the ball joints on the strut. Takes more than an hour, but less than 3 hours.
                        IG: @Baye30
                        • ak-
                          • 12422
                          Come to Diamond Bar ;D
                          1991 325iS turbo
                          • freeride53
                            • 11972
                            Lol i actually did this two weeks ago. The only scary part was compressing the springs b/c little girl.
                            Removing the calipers was easy, tie-rods were tricky upon removal.
                            I was blessed to have access to a shop lift though #tybg
                            BTW abbibi I'm gonna be sliding through DB next Tuesday to pick up some thangs before I drive back to SD.
