orange county mechanic?? or LA people need help!!!!!
  • ///digitalme
    • Dec 2009
    • 2088
    Any mechanics in the oc area? Or a good shop that wont cost an arm and a leg to pin point my misfire?
    My m42 has been having a misfire and I need to smog it this week...I have replaced, valve cover gasket, a few hoses, fuel pump, icv, afm, o2 sensor, catalytic converter, water pump, thermostast...I need someone to do a smoke test, check my igntion wires, coils, and a compression test..I might still have an air leak somewhere. Ive given up and rather pay to pin point my problem...
  • mymonkey562
    • Oct 2013
    • 126
    Have you called ronin autowerks? Theyve done a couple repairs on my 1602 for a reasonable price there in fullerton
    • 2mAn
      Señior Mod
      • 20988
      They are $110/hr ...
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • ///digitalme
        • Dec 2009
        • 2088
        I found a place across my job, they'll be looking at it tomorrow morning. I did find a stripped bolt on my valve cover..could that be causing my misfire? I suspect so
        • ///digitalme
          • Dec 2009
          • 2088
          Update: got a compression test done and it was 180psi on all 4 cylinders... its still running rough.
          Anyone know how to fix a stripped thread on the valve cover? Ill pay and drive to you..need to smog the car this week next week is the last week I can smog it....
          Anyone?????
          • E30SPDFRK
            • 5714
            Come over to 5150 Racing, you won't even have to leave town. Give us a call 714 623 7467
            Byron
            Leichtbau
            • IRON-E
              • 16548
              Wait, you work there with Chris?
              @IRON-E30 aka Edwin:D
              • Chilezen
                I weld cats
                • Dec 2013
                • 1940
                Anyone?????
                Based on this limited knowledge, I guess the valve cover isn't making a tight seal, thus lowering your oil pressure, which will cause it to run rough. That's an easy fix though, pull off the cover, take out the stud, replace. I have extra studs from my old motor.
                Currently building a badass coffee table
                Random stuff on insta @kevanromero
                • Blackout
                  • Apr 2011
                  • 4130
                  Augie, go to Michelangelo Motorworks. Richard who is the owner loves M42s unlike anyone else.
                  23502 Commerce center dr, Laguna Hills CA 92653 [Suite A]
                  949 770 3322.
                  (Tip: bring all the patience and calmness with you when you go)
                  » PARTS FOR SALE
                  » TRANSACTION FEEDBACK
                  • iwantspeed
                    • 3164
                    If it's misfiring maybe replace spark plugs, sparks plug wires and coils?
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                    • ///digitalme
                      • Dec 2009
                      • 2088
                      I replaced the spark plugs with some bosch platinum 4417 I havent tried the wires or coils yet how can I test the coils?
