Used m20 or m50 engine
  • boyRD03
    • Sep 2017
    • 9
    Hello all,
    My 87 325i feels like its dying, does anyone know a place in So Cal that sells m20 or m50 engines that are reasonably priced? My car a 5 speed also so a m50 drops right in, right? Besides new engine mounts and wiring harness, etc. thanks for the help!
  • mtech325
    • May 2008
    • 570
    I think an m20 swap or even a rebuild is going to be the easier solution, as it will bolt right up.
    An m50 does work, but it not nearly as plug-n-play (albeit pretty well documented these days). However, most likely it'll still be a used 100k+ motor that needs a refresh, plus all the e30 swap parts.
    If you have time, give BimmerHeads a call, they'll be able to go over some options and get you pointed in the right direction.
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5612
      m20>m50
      • agent
        Vice Grand Pubaa
        • 7960
        m20>m50
        Originally posted by kronus
        • 2mAn
          Señior Mod
          • 21074
          Originally posted by boyRD03
          Hello all,
          you better do a LOT more research, but I would start by trying to figure out WHY your M20 is "dying" they are pretty tough motors, but they do need to be maintained. You might learn a thing or two
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • McGyver
            • 4636
            What he said. Based on your question, you need to do a lot more research before you tackle an engine swap.
            Also keep in mind, once you swap, you will have to take it to BAR to get it certified before you can smog it. Even with a BAR sticker, some smog shops won't touch it.
            Also also, few mechanics will want to touch a swapped car because they won't want to figure out how the work was done. So either you're going to have to do all the mechanical work from now on, you're going to pay significantly more for diagnostic time at a shop, or you're going to have to be friends with people/shop that can help you.
            I would fix your m20 or refresh a used m20 to put in.
            • 2mAn
              Señior Mod
              • 21074
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • boyRD03
                • Sep 2017
                • 9
                I pulled my valve cover off and found cylinder 1 rocker arm broke off on intake side. I'm leaning towards m20 but just wanted a little input if anyone had the m50 swap done.
                • Stanley Rockafella
                  • Aug 2011
                  • 4062
                  Before you throw the baby out with the bathwater, you might wanna try fixing this minor issue.
                  Then do a compression test to see if it's worth saving/looking into replacement options.
                  • McGyver
                    • 4636
                    well, that would be a problem making the car undriveable.
                    Assuming you have a place to park/work on the car, and since you can't drive it, now is a great excuse to pull the head and replace it with something with some more performance from BimmerHeads.
                    A few things to consider:
                    -Modifying the head is not legal in CA and a modified head may not pass smog
                    -An aggressive cam may introduce drivability issues and require additional modifications
                    -If you get a hotter cam, be realistic about how the car will be used: DD vs track car, stock computer vs. chip/standalone, where in the rpm range you want the power, etc.
                      • 37834
                      Thanks for the referrals guys. We are always happy to help.
                      Grover Beach, California
                      BimmerHeads.com
                      • boyRD03
                        • Sep 2017
                        • 9
                        Thanks guys for all the input, I’m sorta putting the car on the shelf till I get more available funds. My eventual end goal with the e30 is to be a fun daily car, and yes, I’m perfectly content with stock HP. I still need to pass smog by August. My daily is a S2000 and would like for it to be a weekend/track car. Appreciate the help again, till next time!
