Where can I get my front brakes done for cheap?
    Where can i get my front brakes done for cheap
    Go to autozone, buy breaks, rent caliper compressing tool, do work. Should take you 1-1.5 hours. Easy job.
    1991 318is - Sold
    1986 325 - Sold
    Instagram - Lamoursum
      Originally posted by ButtJuice View Post
      Go to autozone, buy brakes, buy $3 large C-clamp, read bentley, do work.
      FTFY bro
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
        Unless you have no room or really don't want to do it, I wouldn't pay a shop to do something like pad replacement. It's a really simple task. It took me less than an hour and I was able to figure it out the first time without a manual (although I advise against doing this if you're really unsure. Better safe than sorry and all that)
        As cletonius said, you can get away with using a c-clamp. When I compressed the piston though, I put the old pad in between the piston and the clamp arm just to be safe. Also, after you reassemble everything and finish, remember to pump the brake pedal until you feel resistance before driving the car anywhere or you're going to have a bad time
        Web Designer / Front End Developer
        My Portfolio & Website
        IG: @w_illriderz
          MakeCopies, I'm in Virginia about 45mins from you. I can do them for you. PM me if you're interested.
          Paypal: vdang5@gmail.com
          Delta Auto Care
          2875-C Towerview Road
          Herndon, VA
          703.435.1375
          My Feedback Thread: Evil_Twin
            I have done brakes in a parking lot before It's not much more complicated then changing a tire
            The only thing with an e30 is usually the jerk before you stripped the Allen bolt that holds the rotor in place
            1989 BMW 325is Lachsilber metallic 5 speed
            2007 BMW 335i KARMESINROT 6 Speed manual
            2011 BMW X5 35I
              in your driveway
              really its that easy!
