Colorado general chat...
This is a sticky topic.
  • lambo
    Captain Scene Points
    • 10953
    #7576
    Originally posted by iamcreepingdeath
    why did the E30 tech help thread get closed?
    Because E30tech?
    I dunno about you guys but I got registered pretty quickly (meaning a few months compared to a year). I just sent an email to the head honcho over there and he approved me.
    • Bimmerman325i
      • 6854
      #7577
      Originally posted by lambo
      Because E30tech?
      Took me as long as it did to join r3v, I think things have changed since 07 on emotech.
      2017 Chevrolet SS, 6MT
      95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
      98 M3/4/5 (stock)
      • Bimmerman325i
        • 6854
        #7578
        forum politics, r3v vs e3t threads pop up so often and are so played out that the mods just close them once they get noticed.
        98 M3/4/5 (stock)
        • 325ix
          • Aug 2009
          • 7783
          #7579
          Same, I joined in 09.
          • iamsam
            • Jun 2008
            • 176
            #7580
            i see. well, let's not get this thread closed I guess!
            (please don't close this thread?)
            To change the subject, it was not the best of ideas to take 5 heavy mech E classes all at once.
            • Cloudbase
              • 1795
              #7581
              I'll help change the subject. I'm looking at Apex arc-8 wheels for the M Coupe with something more track dedicated than Dunlop Star Specs. Any R Comp suggestions? They will probably be 18 x 8.5" in the front and 10" in the rear. Maybe 9.5" and 10.5".
              JOY IS AN E30...
              • fsmtnbiker
                • Feb 2011
                • 617
                #7582
                18" R-Comps
                Are you looking for a good lapping day tire or are you looking to set fast lap times?
                Nitto NT01's are great lapping tires. Faster than street tires, better at high temps.
                Hoosier R6's are the fastest thing out there, but they heat cycle and tread out faster.
                BFG R1's can be fast, kinda numb, heat cycle out quickly.
                Hankooks wear out quickly, from what I've heard (never run them personally.)
                Any reason to continue running staggered? You can get a lot more tire life by rotating them.
                Chris
                97 M3
                01 325
                Weston Auto Gallery
                • Eric
                  • 5142
                  #7583
                  I'm planning on running these conti take offs next year. Can't beat $400 shipped for most sets!
                  +1 on the NT01's those are also awesome!
                  • Bimmerman325i
                    • 6854
                    #7584
                    Can't Moupes fit 10s in the front with proper fitment tires? I know the rear has ample room, but I don't remember for the fronts.
                    The Apex 18x9.5 with a 255/35/18 rcomp is a potent combo, but remember that as you increase wheel width that sufficient tire rapidly jumps in price.
                    Why 18s specifically? The ARCs definitely look awesome in the concave fitment, but tires are quite pricey at that point.
                    98 M3/4/5 (stock)
                    • Roland H
                      • 4480
                      #7585
                      17s don't really have as many good tire options beyond a 255.
                      For the rear of the coupe, I'd run a 285 and then fit the largest front tire possible without rubbing. You have to remember, the S54 Z3 needs all the rear grip it can get.
                      • fsmtnbiker
                        • Feb 2011
                        • 617
                        #7586
                        Not even close. 255's with a lot of camber is still a snug fit. Gotta trim the clamshell to go big.
                        Chris
                        97 M3
                        01 325
                        Weston Auto Gallery
                        • Bimmerman325i
                          • 6854
                          #7587
                          This I did not know.
                          98 M3/4/5 (stock)
                          • Bimmerman325i
                            • 6854
                            #7588
                            Truf.
                            98 M3/4/5 (stock)
                            • Cloudbase
                              • 1795
                              #7589
                              18" R-Comps
                              Good lapping day tire that will get me descent tread life. I don't know what to expect from a full season. I plan on doing as many NASA PDX's as I need to time trial. Hopefully just one weekend. Then the TT's at HPR and PMI, maybe something like Hastings. Plus a CCA school. That would probably be 6-8 weekends throughout the season. Fast lap times would be great, but if I'm going to track that much longevity will need to be considered. From what you've said Nitto's might be the answer.
                              I've considered a symmetrical set up before, but w/ the M Coupe's funky rear offset it would require a massive spacer. I want a more neutral setup, but retaining some of the built in balance would be responsible at this point.
                              Thread Bookmarked
                              Was going w/ 18's due to sizing. 9.5 in the front is the most without massive modification if I remember my research correctly.
                              +1 The more grip the better. Next year I will have a 3:46 in place of my 3:15LSD which will only require more delicate throttle application. The scariest times I've had in the M Coupe have been stabbing the throttle on tight turn exits.
                              Have you seen this on Z3's before. I was going to go with Vorshlag camber plates on my stock suspension (because they will work with coil-overs later). I have a resource in the M Coupe world running that set up, so I can pull on his experience.
                              JOY IS AN E30...
                              • fsmtnbiker
                                • Feb 2011
                                • 617
                                #7590
                                I had them on Mark's Z3 M-Coupe. Had 235s on 17x8.5s with 2-degrees of camber and it was snug. New owner has 245 Hankook RS3's which hardly fit with 2.5 degrees. If you're running 3-3.5 degrees I think you could probably fit 255's or maybe 265's. This was on Z3 M-Coupe with KW V3's.
                                In the rear I don't think it would be tight until you were running 305's.
                                Chris
                                97 M3
                                01 325
                                Weston Auto Gallery
