Timing Belt Party / Check - In
    Originally posted by blefevre View Post
    Yeah, I can't wait for me MM pistons. Higher CR, valve pockets, bored and longer stroke = happy time.
    nice!! Which MM pistons you going with? I was looking at them a while back
    2017 Chevrolet SS, 6MT
    95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
    98 M3/4/5 (stock)
      2900 sport pistons. 10.0 CR, 2mm over bore, works with stock "I" rods and an eta crank, comes with the valve pockets. I have almost sold the DASC a few times to fund it, but then I would probably get kicked out of the house or something.
      - E30, DSM, Golf R, Mazda 3 Skyactiv
        wicked. I was looking at doing their 3.1 rally stroker but went a different direction
        98 M3/4/5 (stock)
          That would be sweet. I was going to go the swap route but it's just too common. After the supercharger and the E30 beast setup I will either do the M30 or S50 swap into some E30. Or turbo the jeep, BAH too many decisions. Lets just hope I never graduate otherwise this will get out of control.
            Hopefully in a V12 direction.
            89 325i (Sold)
            95 M3 (Track Car in Progress)
            2001 4runner (DD)
              With turbos too!
                yummmmmmm
                89 325i (Sold)
                2001 4runner (DD)
                  no kidding. If I actually had money....? HPF S54 E30 would be sick.....
                  V12's just the idea of the moment. I tend to go in different directions. Cammed high compression M70 or M73 sounds badass to me right now, but ask me next week and it'll be another engine.
                  98 M3/4/5 (stock)
                    With turbos too!
                    don't forget the nawz!
                    98 M3/4/5 (stock)
                      Don't forget to strait pipe it.
                      89 325i (Sold)
                      2001 4runner (DD)
                        quad side straight pipe exhaust.
                        98 M3/4/5 (stock)
                          I've heard it's only 40 lbs heavier since it's aluminum block and heads, but the only data I can find online says it's as heavy as a euro S50, so 330lbs. Dunno which to believe honestly, this is for complete motor with ancillaries.
                          The M73 can't be cammed (like it matters for this build) but is a good bit lighter than an M70 and has 326 hp and 361 ftlbs. 5.4L 361 ft-lbs!!!!!
                          M70: 300/326 hp/ft-lbs, max stock rpm 6400. heavier, but can be Schrick'd.
                          M73: 326/361 hp/ft-lbs, max stock rpm 6400. Lighter, but less tuning potential
                          Megasquirt either to 7000 + custom fabbed long tube headers = winnnnn!
                          Dyno of six speed converted M73:
                          and a vid of a cammed ITB M70 in an Ultima:
                          ^ours wouldn't sound like that....but goddamn.
                          The dyno is of an M73 with extrude honed manifolds and BBTBs IIRC.
                          Dude, eff that. I have two S52s FS, I'll cut you a deal. ;)
                          With turbos too!
                          yes pls....
                          Megasquirt + V12 will be three bitches and a half. We'd have to run 2 EDIS-6 systems (we can use one trigger wheel though), as well as two MSII ECUs. At that price point, we need to evaluate alternatives. I'm not sure if the M70 has a cam position sensor, but I'm pretty sure that the M73 does, which means we can run fully sequential ignition if so desired...
                            brilliant!!!!!!!
                            89 325i (Sold)
                            2001 4runner (DD)
                              I tried to get a 318is the other day but it sold right away, otherwise you would only have one S52. :)
                                Eff that, mount it in back seat. Mid-engined-V12-E30 FTMFW.
