Compression tester
  • conway
    • 366
    Compression tester
    Any one have a quality brand one I could borrow? I wanna run the numbers on my cafe racer. Mines back in NJ, and I don't think it ever read correctly. Six pack for your troubles.
    Eastwood fender roller available for rent in Boulder. PM ME
  • Roland H
    • 4480
    I have one. If you can't find one closer, or are willing to come pick it up you can certainly use it.
    • conway
      • 366
      Sounds good, i'll probably need it next week, i'll give you a ring.
      • downforce22
        • Aug 2009
        • 3189
        i could probably use one of these to test the piston rings on my car, yeah?
        • Roland H
          • 4480
          Yes, compression tester will do that. If the number is low, which I bet it is, then pour some oil in the cylinder and then do the test again immediately after. If the compression numbers go up significantly, you have a ring issue.
          A leak-down tester is also handy too.
          • conway
            • 366
            Also a low number that doesn't jump with oil usually points to valve sealing problems.
            • downforce22
              • Aug 2009
              • 3189
              any chance i could grab it this weekend and borrow it for a while?
              • Roland H
                • 4480
                A while? That's vague lol.
                You can definitely borrow it for a week, but I'll need collateral + beer or chipotle.
