Help with output shaft seal
  • spiDmang
    • 3941
    Anyone have a thin-walled 30mm or 1-3/16in socket I can borrow to get my output flange off of my trans?!
    I'm located In lynnwood!
    Help!!
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
  • 2mAn
    SeƱior Mod
    • 20711
    hope you got it done brotha!
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • Grand525
      • 491
      Just get a socket for GM Oil Pressure Sensor. It's about $10 at local Vatozone or OhReally.
      USe MAPP gas torch to heat it, or you'll be using a few of those sockets.
      • spiDmang
        • 3941
        Maybe it'll be done today! Still gotta wait though cuz I have a shifter rebuild kit on the way plus some other goodies!
        GREAT info!!! Thank you... How much do torches go for anyway?
        • Killacortes
          • 1937
          I have one man but im all the way down up in Anacortes. I used a impact gun on the highest setting to break that flange loose
          r3v does not fuck around. First you get banned, then they shoot you
          • DrJosh
            • 2011
            Like $15 at mclendons and they have their own starter.
            Originally posted by Sonny
            I am a meme for our community.
            • spiDmang
              • 3941
              So I tried the gm oil pressure socket and its way too small
              • Grand525
                • 491
                Is it AT or manual? Idk if they are the same or different.
                Maybe the safety collar is in the way? It needs to be removed.
                • spiDmang
                  • 3941
                  It's a manual, and from my research, the nut is 1-3/16 or 30mm. The gm oil socket is a 1-1/16...
                  • Grand525
                    • 491
                    Idk if there's a discrepancy about this GM socket.
                    I've used it a couple of times, and it was GM Oil Sending Unit socket. It was 1" 3/16.
                    See how they show 2 different size:
                    http://www.northerntool.com/shop/too...9088_200379088
                    http://www.sears.com/shc/s/p_10153_12605_SPM5784571801P
                    • spiDmang
                      • 3941
                      Hmmm interesting...where did you buy yours from? I'm picking up a socket from a buddy of mine, so it doesn't matter now, but I appreciate the help :)
