Heater problem.
  • devin6519
    • Jul 2011
    • 89
    Heater problem.
    My heater only works when I drive, and it does not start actually blowing heat until I hit about 40 MPH. And even when I am driving, the speed of the heat being blown is very slow. I suspect that it has something to do with the blower motor, but I am not sure. Any thoughts of what this could be? I am getting really tired of having to drive down the road with my window down in this 35 degree weather, and in the rain. It gets old fast...
  • bmwm42
    • 6300
    It would not be your blower motor. You should have heat anytime. Have you done changes to your cooling system recently?
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • AbeSonic
      Price check on Vagiclean, aisle five. I repeat: price check on Vagiclean, aisle five. That's Vagiclean. We've got a customer down here with a full-on fallopian fungus. I'm baking a loaf of bread and I think it's sourdough.
      • 3635
      Resistor probably took a crap dude. Does it work at all the speeds? Does it make a whining noise?
      out dated sig is out dated
      • ck_taft325is
        • Sep 2007
        • 6880
        Not enough coolant usually.
        Need a part? PM me.
        • EN318isPDX
          • Oct 2007
          • 4373
          Originally posted by devin6519
          I am 95% positive that I fixed it. Someone told me today that it was the radiator. So I bought a bottle of the super radiator cleaner. So i drained my radiator and I ran the cleaner through my car. The first 15 miles the car ran hotter, but I let it sit for about 4 hours and I came back and started it up and drove it for another 15 miles and it drives at average running temp, and it idles just ever so slightly above half. I let the car idle for 10 minuets and it didn't go above halfway between the half and 3/4 mark on the coolant gauge. So if anyone is experiencing the problems I described earlier I would give that radiator cleaner a try.
          Sounds like you are burning coolant or failed to bleed it correctly. You need more coolant and did you ever fix the clutch fan?!
          • devin6519
            • Jul 2011
            • 89
            Yes I replaced all 7 main cooling hoses and a new thermostat. Bleeding it took over an hour to bleed this car after everything was done. Bleeding e30's are a pain in the ass!!! And none of the speeds work. It really just depends on my speed.
            • iansane
              • 1343
              Sounds like your blower motor isn't blowing at all and the only air your getting is just being forced into the cabin from speed?
              Are you getting power to the blower motor?
              84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
              • EN318isPDX
                • Oct 2007
                • 4373
                Sounds like you hooked up the resistor wrong when you replaced it or you didn't replace the fuse
                • bmwm42
                  • 6300
                  Yup resistor or fuse issue unless your blower motor was whining before I doubt it went out suddenly.
                  • EN318isPDX
                    • Oct 2007
                    • 4373
                    He's already replaced the resistor so I assume its the fuse.
                    Everything is normal until I use my heater. It's only when the heater is on. I was told that it is the blower motor resistor. So I'm going to try that out.
                    • bmwm42
                      • 6300
                      dont see where he mentioned he replaced the resistor in this thread and if he did there is no way to fuck up installing it
                      • EN318isPDX
                        • Oct 2007
                        • 4373
                        He has like 3 or 4 threads related to heating issues.
                        • devin6519
                          • Jul 2011
                          • 89
                          I never actually replaced my resistor.
                          • EN318isPDX
                            • Oct 2007
                            • 4373
                            So have you checked fuse? I'd start with replacing the resistor and fuse
                            • devin6519
                              • Jul 2011
                              • 89
                              I will replace the fuse and re-bleed the stupid lines. And if after that it still has issues ill replace the resister if need be.
