My new E30
  • mcdougal
    • Nov 2014
    • 251
    Been cleaning up the engine bay. Went from this...
    To this...
    Going to spray it black before the motor goes in. Any tips on which wires I can remove?
    • HarukoE30
      • Nov 2011
      • 1057
      All of them is what KeithM would say. Depends how clean of a spray you want to do? Prep is key when doing it right :up:
      Welcome to the community btw
      Originally posted by James Crivellone
      1) The internet is NOT serious business.
      • mcdougal
        • Nov 2014
        • 251
        Finished cleaning up the engine bay and gave it a couple coats of flat black.
        And my motor showed up today!
        I really have no idea what I'm doing but I'd like to get it running by March 1st. If anyone has done the swap and wants to lend a hand I pay in all you can eat pizza and beer.
        • ArtFoodBMW
          • Feb 2014
          • 765
          The bay looks awesome, Good luck with the engine swap!
          • mcdougal
            • Nov 2014
            • 251
            Dropped the motor in today. Now it's time to figure out where everything goes.
            Prior to dropping the motor I replaced the following: valve cover gasket, oil pan gasket, water pump, thermostat housing, main belt, wired in oil pump nut, pilot bearing, rear main seal, throwout bearing, and the clutch and pressure plate. Hopefully I did everything right.
            • AustinK425
              • Sep 2011
              • 831
              Might not be a bad idea to do the oil filter housing gasket.
              $4 save you the headache later
              • mcdougal
                • Nov 2014
                • 251
                That's on my to-do list, just haven't gotten around to it.
                • FireFight
                  • Mar 2012
                  • 1367
                  good for you man im glad this didn't end up at pick n pull with that destroyed m20
                  WTB:m60b40 in PNW
                  Zachary Ripley
                  85 318i M50B25tu.
                  92 525it 5 speed.
                  80 244gl (m60 prepping).
