help me make the picnic
  • 5Toes
    • 9836
    so my m42 sedan is running absolutely terribly. It started out of nowhere and I diagnosed it to find that the o2 sensor relay was dead and the ICV was frozen. Ok cool, I replaced them and threw new plugs in (NGK BKR6EK) the car idles now rock solid. no misses or anything.
    if you go over 15-20% throttle the engine does nothing. you hear the intake wide open but no power whatsoever. its as if the ignition is turned off, but the tach doesnt drop or anything. the throttle response all around is SHIT. if idling I can go WOT and the idle actually doesnt change just the engine starts missing like a mofo
    the car runs better in open loop than closed loop. from what I have diagnosed all the engine's sensors are operating correctly (coolant temp sensor, AFM, TPS). I had a fuel pressure gauge on it last week when diagnosing and it read in spec with no jumps or anything.
    I do NOT want to miss the picnic, please help me figure out what sensor is causing this. TIA fellas... Im pretty stumped
  • Gerta
    • Sep 2009
    • 2119
    Have you tried bringing it back to stock?
    Parts Collector and Former Houndstooth interior junkie.
    • RainRider
      • Aug 2014
      • 362
      Look... I'm no brain head hear but when a engine idles ok then poops out giving it gas most likely a vac leak. Stab in the dark here. Smoke test.
      • delamaize
        • Nov 2013
        • 1463
        Originally posted by rainrider
        look... I'm no brain head hear but when a engine idles ok then poops out giving it gas most likely a vac leak. Stab in the dark here. Smoke test.
        +1
        Dumpster Fire Pilot
        • Habla
          • May 2004
          • 1470
          Arrrr, maytey!! How be yer fuel pump? Ye might be havin' a wee bit of a delivery problem... Arrrrrr
          SIncerely,
          -beer
          -Peter
          318is slicktop | F15 35dM | F250 SD
          • DrJosh
            • 2011
            Smoke test and fuel pressure
            Originally posted by Sonny
            I am a meme for our community.
            • BECKSTER
              • Jun 2015
              • 667
              Rip a faaaat vape inside the intake and see where it leeks.
              1990 Alpine 325is
              1992 Schwarz 325ic (sold)
              • 5Toes
                • 9836
                I installed a brand new fuel pump (had in the garage so why not lol) and got a fuel pressure gauge on the car tonight. Didnt test it too thoroughly cause of daylight but I left the gauge on so I can tomorrow. Engine built pressure quickly up to 48psi with new fuel pump then immediately dropped off to a steady 39psi at idle. the moment you open the throttle the engine dies. I have a video but it honestly sucks and its hard to read the gauge unless zoomed in. the pressure starts bleeding off immediately down to 10psi where it kind of holds steady.
                tomorrow Im gonna go HAM checking every single thing on the intake side of the engine
                • spiDmang
                  • 3941
                  Good luck, toes. I agree with Brad (Rainrider) as well. Vac leak sounds like your issue. Could be a substantial one too. Smoke test it dude
                  91' 318iS - S54/6MT Swapped
                  08' E90 M3 6MT - Daily
                  Originally posted by IronJoe
                  Originally posted by 2mAn
                  • lambo
                    Captain Scene Points
                    • 10953
                    you're in my thoughts and prayers
                    hope that helps
                    • e30josh
                      • Sep 2004
                      • 718
                      hope that helps
                      Lol.. Toes gets all the attention!
                      I have a mobile smoke tester if you can make it up to anacortes 😳
                      • george graves
                        • 20003
                        Why can't I help but to think of this?
                        With that - my e30 won't start - might not make it to the picnic. Replaced coil, pump, ecu, wires, CPS tests good. I've got to remove the radiator to check the cap/rotor. Damn you m30 swap.
                        So I feel your pain. My thought and prays are with you as well.
                        Originally posted by Matt-B
                        • djjerme
                          • 5082
                          ..I got a spare M20 you could install.
                          But then you may never put the M42 back in it.
                          (someone had to go there..)
                          2016 Ford Flex
                          • 2002jm
                            • Sep 2005
                            • 2076
                            You have changed the filter?? I had a car e30 325 that would idle fine, but with wot the pressure went way down because of the filter being dirty....
                            Just an idea:)
                            jm
                            • delamaize
                              • Nov 2013
                              • 1463
                              I got a SETA/Eta bastard longblock sitting on a engine stand also...
                              Dumpster Fire Pilot
