323i Engine Partout, Flywheel, Driveshaft
  • dahows
    • Nov 2009
    • 583
    Many good parts available from this 100k engine. Been sitting in my garage for a few years. Flywheel and driveshaft available (same length as other manual driveshafts). Let me know what you need.
    84 323i
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4502
    I'm curious- is the front upper timing cover and engine lift bracket different? I am assembling an engine with a 731 head (should be what's on that motor) and it doesn't have provisioning for the dowels that center the bracket.
    If they're different than a standard M20 I'd be interested in those items.
    • dahows
      • Nov 2009
      • 583
      The front cover is certainly different than other M20s...not sure about the engine lift. I'll provide some additional pictures tomorrow.
      84 323i
      • dahows
        • Nov 2009
        • 583
        323i Flywheel...not sure the weight on this, 14 lbs. $sold
        84 323i
        • dahows
          • Nov 2009
          • 583
          323i Manual Driveshaft. You'd probably need to change the center bearing for other applications but the length is the same as other m20 manual applications. $200.
          Click image for larger version  Name:	driveshaft-1.jpg Views:	63 Size:	115.2 KB ID:	9966754
          Click image for larger version  Name:	driveshaft-3.jpg Views:	54 Size:	117.0 KB ID:	9966755
          Click image for larger version  Name:	driveshaft-4.jpg Views:	54 Size:	111.6 KB ID:	9966756
          Click image for larger version  Name:	driveshaft-2.jpg Views:	54 Size:	54.0 KB ID:	9966758
          Click image for larger version  Name:	driveshaft-5.jpg Views:	51 Size:	105.8 KB ID:	9966757
          84 323i
          • AWDBOB
            hooptie connoisseur
            • Aug 2013
            • 4502
            Ah, just had a brain fart. The 323i front cover won’t have provisioning for the cap/rotor and associated bits IIRC?
            • dahows
              • Nov 2009
              • 583
              Correct, unless you're running a different distributor you'll want the standard cover.
              84 323i
