Kamotors Rivet on Fender flares.
  • kamotors
    • Nov 2007
    • 7102
    #226
    Originally posted by Hugo Stiglitz
    Forgive me if I missed it, but what's the price on a front/rear set for early model/plastic bumper conversion?
    early model set is
    $325 shipped
    7speedshop.com
    • kamotors
      • Nov 2007
      • 7102
      #227
      just thought I would add some notes to help with installs for customers.
      in order for the front flares to sit 100% flush you need to cut out at least 90% of the original flare so that it does not make contact with the mounting points on my flares.
      You will notice when you do test fitting that the front requires twisting to fit but after you cut out the OEM flare it will fit flush.
      also DO NOT drill a hole too big other wise you risk the screws popping threw.
      DO NOT over tighten any screws, do even tightening on all screws do not tighten one all the way when others are still loose, get them all to lets say 25% tight then get them all to 50%-75% and then 100%.
      I test fit ALL flares before I ship them but things like the early model chrome strip door trim and even bumper alignment may create the need to file edges.
      I am NOT responsible for the modifications you make to your car. I've installed these flares first try with no mistakes and with great fitment If you take your time and are capable of sanding or filling you will also get a great fit.
      If your looking for flares that will have OEM prefect fitment right out of the box I would suggest you make your own because I have seen fitment on my flares and other companies flares and non are OEM like without a little bit of body work.
      7speedshop.com
      • gswrs
        • 24
        #228
        I have a 1990 325is. How much would a set cost, and when will they ship?
        • kamotors
          • Nov 2007
          • 7102
          #229
          I'm doing $300 shipped for this month:) takes me around 1 week to make
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #230
            7speedshop.com
            • Q5Quint
              • Jan 2005
              • 725
              #231
              wooooaaahhhh count me in as well good sir- these look a bit tougher than the dtm set. If I can squeeze in some 245/255 that would be epic.
              • kamotors
                • Nov 2007
                • 7102
                #232
                245 fit very easy at like offset zero on a 8" wheel, 9" wheels with a 255 width will fit at offset 12-10 pretty comfortably as well..
                7speedshop.com
                • Jurt
                  • Nov 2011
                  • 347
                  #233
                  So how much for an early model set with plastic bumpers shipped to Calgary Alberta Canada?
                  Feedback
                  http://www.r3vlimited.com/board/showthread.php?t=270560
                  • Northern
                    • 5075
                    #234
                    Any updates on the early model extra wide? I keep forgetting where this thread is.
                    Well maybe a regular early set would work... its for an ix, and I want to run a square setup, so im worried about fitment of a 17x9 or 10 up front.
                    Originally posted by priapism
                    Originally posted by shameson
                    • kamotors
                      • Nov 2007
                      • 7102
                      #235
                      a 17x9 will fit square VERY easy at ET 12 up front, but a 17x10 will not fit up front with any decent sized tire.
                      Ultra wides may not be made.
                      7speedshop.com
                      • jim325
                        • 228
                        #236
                        I wish I could afford these to get rid of the shitty looking 2002 style flares I put on. They look much better and likley offer up more tire space.
                        89 325i: 86 535i motor+trans, JE forged pistons, MLS head gasket, ARP head studs, Comp turbo, GoodNTight b34 turbo manifold, e30.de motor mounts, AKG 75D engine/trans mounts, custom 3" exhaust, intercooler, MS2PNP, Megan Racing Coilovers.
                        • kamotors
                          • Nov 2007
                          • 7102
                          #237
                          so I may of run into an issue with my fiberglass guy,he seems to of disappeared with my money. So I'm currently shopping around for a new guy to do all the mold work, I'll see how things play out.
                          7speedshop.com
                          • Jurt
                            • Nov 2011
                            • 347
                            #238
                            so does that mean a hold on orders?
                            Feedback
                            • kamotors
                              • Nov 2007
                              • 7102
                              #239
                              I'll let you know this weekend
                              7speedshop.com
                              • Jurt
                                • Nov 2011
                                • 347
                                #240
                                Sounds good! I'm ready to purchase once you have things figured
                                Feedback
