I am currently sold out unfortunately! Due to order size to justify the CNC set-ups and orders trickling in slowly I really would have to do a group buy if there is enough interest.
5 Lug AND Big Brake Kit (BBK)
The Lineup in order of appearance:
91 535i
91 318is 5 Lug/E46M3 Brakes
91 325is w/ S52
88 Vert Plastic Bumper Swap
88 M3 ;D
91 325ix 5 speed
89 Vert Royalblau Metallic
73 2002
1986 325es --> is swap Rallycross Car!!
1995 Chevy G30 Tow Rig... *I SOLD A CAR!!*
1993 525i Granitsilber Metallic Touring
Need a 91 M5 bad but wife would shoot me...twice
*UPDATE: got a 93 M5 and still alive
1972 Jeep Wagoneer
1975 2002 five speed
Check out:
Elhartspeedshop.com
sigpic -
What hubs are you using in the rear? I was thinking about doing a similar setup, but running Z4 hubs to do the job so I could retain the bigger half shafts.WNY e30 Group on FB, feel free to join if you're from the area!
@mriterphoto on instagram
"Being airborne in an e30 is one of the worst ideas that I've done more than a couple dozen times"
me-"I've got one of those rare 7cyl low-comp S62's"
MattAvino- "Those aren't rare"Comment
I believe the z4 hubs can be used, but needs to space the rotor by 2.5mm. E30 M3 hubs works and does not need to use spacers.Comment
CONFIRMED! Z4 Hubs installed WITH e39 530i rear calipers. (not 540i)
This is the Z4 hubs installed using the bracket provided in the kit with NO spacers installed. Although i might consider putting some small ones in there for better centering. In the last picture is a 3 position code listed on the top/front of the caliper that indicates the caliper dimensions. The 530i calipers have the same last two dimensions which is rotor size and thickness. As I've been told by a german friend, the first number indicates the brake cylinder diameter which would make this 2mm larger than the 540 calipers.
I would be in if the price is the samesigpic
Gigitty Gigitty!!!!
12 135i M sport cabrio grey/blackComment
Something's wrong here...the E39 530 and 540 brakes are the same...and that caliper and part number aren't from a 530. Maybe E34?CONFIRMED! Z4 Hubs installed WITH e39 530i rear calipers. (not 540i)
Rears on E39 are 34211163649 and 34211163650. The low-spec 520is have 34211163393 and 34211163394.Comment
Thanks for the interest!
I am working to get some more machined in a group buy format.
See thread:
91 535i
91 325is w/ S52
88 M3 ;D
91 325ix 5 speed
73 2002
1972 Jeep Wagoneer
Check out:
Elhartspeedshop.com
sigpicComment
Hey elcoy, you should consider selling a kit with the rear brake brackets having 2mm less aluminum to fit z4 hubs instead of the costly e30m3 hubs. Even with machine shop costs, i still ended up saving about $200 by using z4 hubs.Thanks for the interest!
See thread:
http://www.r3vlimited.com/board/showthread.php?t=383082Comment
