Spectra Premium Gas tank
  • clydesdale
    • 631
    #46
    After some research, it seems the electrical connection for the in tank pump is hanging on by a thread. Is this common? Requires new pump, I guess? The connection to the fuel level sending unit is intact and can be removed. The other connection I speak of popped off as soon as I touched it. It rusted off the car. Where does this connection go to?
    • moatilliatta
      • 6152
      #47
      The early and late cars take 2 different types of connectors.
      Late is a sealed connector terminal that matches thinks like coolant reservoir level sensor in a late car.
      Early connector terminals match the same as your front turn signals.
      Both can be bought new from BMW, I can get the P/n if that helps.
      @Zakspeed_US
      • jjc034
        • May 2018
        • 107
        #48
        Originally posted by moatilliatta
        The early and late cars take 2 different types of connectors. Late is a sealed connector terminal that matches thinks like coolant reservoir level sensor in a late car. Early connector terminals match the same as your front turn signals. Both can be bought new from BMW, I can get the P/n if that helps.
        So odd thing is that I got a late model tank but it only fits ~12.5gal. Unless my fuel level sender is off, it does not fit 16gal when needle is very low Sent from my SM-G973U using Tapatalk
