German Engineering Coilovers
  • RGCintha29073
    • Dec 2009
    • 471
    #166
    Got my box today and I just installed the rear. Really nice so far! Thanks!
    • jrobie79
      • Mar 2006
      • 2526
      #167
      what would you recommend the billy sports be re-valved at for these?
      I have em on all 4 corners, but I'm pretty sure the front two are blown, so while I'm getting em fixed figured I'd get em re-valved.
      1991 318i ---- 308K - retired
      • einstein57
        • Jun 2007
        • 10780
        #168
        When you fill out the service sheet tell them what rates you will be using.
        www.gecoils.com
        • DIIRTY-30
          • 1665
          #169
          Sorry no pics of the install yet finally got around to cutting and what not. Slapping them on either today or tomorrow.
          Bilstein Sports + GE coils
          H&R SPORTS vs HC
          BLUE NOSE - M62 SWAP
          THE E30 + 1 BUILD
          • Jdesign
            • Jun 2012
            • 198
            #170
            Is there only one set of spring rates available?
            • einstein57
              • Jun 2007
              • 10780
              #171
              I offer any spring available in the hypercoil catalog. I only have the custom springs in the one rate.
              www.gecoils.com
              • RGCintha29073
                • Dec 2009
                • 471
                #172
                ^ Inbox full bro!
                • Anthony B
                  • Nov 2012
                  • 308
                  #173
                  Hoping you get more in soon cause I need these in my life. I've been hunting for a coilover set up that doesn't require cutting up & welding in like BC's.
                  • einstein57
                    • Jun 2007
                    • 10780
                    #174
                    Adjuster have been paid for. Just patiently waiting for the machine shop
                    www.gecoils.com
                    • herb325i
                      • Jul 2012
                      • 39
                      #175
                      my whiip with rears on only. lowest setting. Waiting for struts to come in to put the fronts on. GE coils tho mang....SO SWEEEET
                      [IMG][/IMG]
                      • RondoAcapriccio
                        • Jul 2011
                        • 524
                        #176
                        when can i purchase these?
                        • samurai pizza cats
                          • 457
                          #177
                          Originally posted by einstein57
                          adjuster have been paid for. Just patiently waiting for the machine shop
                          [ATTACH]75595[/ATTACH]
                          keepin it real since 1990
                          • einstein57
                            • Jun 2007
                            • 10780
                            #178
                            I called to check up and they said they will be shipping out by the end of the month.
                            And for those of you thinking about sectioning your strut tubes this is how i do it. I had 25 sets of weld on stainless steel collars made for those who are interested in going the same route.
                            The strut looks different then anyone i've ever cut up before. Although i could be mistaken cause i've been dealing with m3s lately.
                            After cutting off the dust shield i ground down the factory weld and cut the tube 2" below that. I then cut it again at the bottom of where the factory weld ended. I use a pipe cutter to get a perfect cut.
                            Then i used the tool i made to perfectly weld the two pieces together straight as an arrow.
                            Finally busted out the ix inserts i had re-valved a year ago. I used stock i insert sleeves and shortened them 2 inches. That way i get maximum travel and no spacers. With a 6" spring it sits perfectly on the adjuster with out play when its at the maximum height. The car tucks 235/45/17s tires at the highest setting. Shortened i sleeve on the left. Regular ix sleeve on the right.
                            www.gecoils.com
                            • tinkerputzer
                              • Jun 2008
                              • 508
                              #179
                              Great work Nigel. Interesting idea on shortening the e30 sport stand tube to use with the ix insert to avoid running a spacer. I might do this as i am in the same boat. My ix inserts are currently down at bilstein.
                              • Northern
                                I like cupcakes & sh!tboxes
                                • 5270
                                #180
                                How much does an ix insert revalve/rebuild run now? I have an old set of ix hd's that came out of my ix I keep thinking about...
                                Originally posted by priapism
                                Originally posted by shameson
