German Engineering Coilovers
  • dmoney(AB)
    • 1372
    #136
    Originally posted by einstein57
    que?
    The owner of the m3?
    mtech1/2jzgte/r154/275tire
    function>form
    • einstein57
      • Jun 2007
      • 10780
      #137
      Thanks for the review. I used to be one of those H&R race guys who would say there was no reason to go with coilovers until i drove an e30 with linear springs rates. I was sold.
      The orange car is one of the cars the Castros built for the tour. I have not personally driven any of the cars but i have been told the suspension setups compliment the cars very nicely. I believe two of the cars are on Bilsteins and one is on Konis.
      Crappy cell phone install pic.
      www.gecoils.com
      • oliver.r
        • Mar 2012
        • 3839
        #138
        do you know if they sectioned the strut housing by any chance?
        • einstein57
          • Jun 2007
          • 10780
          #139
          No sectioning. Only perch cutting was done for aesthetics.
          www.gecoils.com
          • 1991 e30 bmw 318is
            • 523
            #140
            Originally posted by Northern
            I was driving on a few winding roads this past weekend, and it really made me appreciate this setup...
            I have GE Coils all the way down in front and .9" from all the way down in back, Billy sports with cut bumpstops, cheap dirty camber plates, and offset CABs.
            I used to have the same setup with H&R Race, and I found I would bottom out up front on practically any bump that was anything more than small. The front spring rate on those was definitely not picked with a 6-cyl car in mind.
            With the 450lb GE springs up front, the car rides and feels a ton better. I don't even bottom out on the larger bumps I hit, and the whole car feels so much more planted. I also don't need to space my upper spring perch down from the camber plate for clearance like I did for the stock perch, so the front sits lower, but has more shock travel.
            For the same price, this is a way better option than any of the oem-diameter spring options out there, even if you're not into cutting your housings.
            Sorry for the rant, but I'm really impressed with how they turned out.
            cant wait to check it out... this is the stuff I'm going to be using on my new car. but i will cut down front housings and use ix billys... maybe little heavier rates would be good for my plans also.... cant wait to get this garage built.
            any pics of the set up troy?
            91 e30 318is M50 SOLD
            http://www.r3vlimited.com/board/showthread.php?t=149570
            92 325 vert project
            http://www.r3vlimited.com/board/showthread.php?t=341370
            • JGood
              • Jan 2004
              • 7959
              #141
              FYI, iX Billy's are way too soft for these spring rates. iX Koni SA's are just about perfect, though.
              e30 restoration and V8 swap
              24 Hours of Lemons e30 build
                • 523
                #142
                ix HD billys are same dampening as normal e30 billy sports.. just shorter i thought...
                92 325 vert project
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5284
                  #143
                  ^+1 to that. As JGood posted before:
                  BMW 325I HD FRONT
                  COLL/EXT: 530.0/618.0
                  REB/COM: 2320/800
                  BMW 325I SPORT FRONT
                  COLL/EXT: 515.0/597.5
                  REB/COM: 2330/755
                  BMW 325IX 4WD F
                  COLL/EXT: 438.5/511.0
                  REB/COM: 1365/465
                  I checked out my new iX HD's that I bought for my iX vs the old billy sports on my iS, and I could feel the sport was stiffer, even after a few years of beatings.
                  No idea why they're so much softer, may have to do with the caster of iX struts?
                  As for pics, the closest thing I have is:
                  Touring is H&R Race/15mm drop hats with slightly oversized 17's, iS is on euroweaves/RZ378 with 205/50's. They seemed about the same height in front before the 17's went on.
                  Originally posted by priapism
                  Originally posted by shameson
                  • einstein57
                    • Jun 2007
                    • 10780
                    #144
                    If you can find a cheap used set of ix Billies then its worth having them re-valved. Otherwise get Konis.
                    www.gecoils.com
                    • einstein57
                      • Jun 2007
                      • 10780
                      #145
                      Almost out of adjuster. I have about 3 kits left and then there will be an 8 week wait for some more to come in.
                      www.gecoils.com
                      • DIIRTY-30
                        • 1665
                        #146
                        Looking forward to installing.
                        BLUE NOSE - M62 SWAP
                        THE E30 + 1 BUILD
                        • ST1G
                          • Oct 2012
                          • 6690
                          #147
                          Are you still selling the GE coil over's?
                          Edit: Sorry I thought this was the Group buy thread which I already read. I'll read through this thread.
                          PM'd
                          • einstein57
                            • Jun 2007
                            • 10780
                            #148
                            I have one set left but one of the rear adjuster is red. Got left out of the anodizing box. I can give a $10 discount on the mix matched set. New sets should arrove in about a month.
                            www.gecoils.com
                            • VadimE30
                              • Jul 2013
                              • 16
                              #149
                              Hey einstein57, I just bought a 325es and it s my first bmw ever, so GE's are coilovers and what else would i need to buy if nothing how much is the whole set?
                              • einstein57
                                • Jun 2007
                                • 10780
                                #150
                                If your car still has the original shocks you'll need to replace them with premium units like bilstein sports or Koni Sa
                                www.gecoils.com
