Turbo M50 OBD + ECU Quesetion
  • hreverman
    • Oct 2020
    • 20
    I've been researching if I need to convert to OBD2 or if I can stay OBD1 and I have thoroughly confused myself at this point. I've build a 3.0 M50tu and am going to boost it. I was under the impression I could stay OBD1 and just run a standalone ECU, like the Link G4X. Is this incorrect? Do I need to convert to OBD2?
  • ForcedFirebird
    • Feb 2007
    • 8300
    You can just get the g4x. I just installed one in a customer car and took about 3/4 day to get the PCB installed in the stock case, hook up the wide band and fiddle with a few settings. Fired up on the first crank.
    john@m20guru.com
    Links:
    • Northern
      I like cupcakes & sh!tboxes
      • 5262
      If you're OBD1, I agree with the Link E36X PNP ECU that John mentioned. Basically the best thing going right now for PNP ECUs.
      Converting harness/ECU/sensors to OBD2, then getting a blow-thru MAF could easily be half the cost of the E36X already, and then you're stuck logging at 12Hz or less and can't live edit. It works for me, but I think choosing the E36X is a no brainer.
      Originally posted by priapism
      Originally posted by shameson
