What maf should I use?
    • 34844
    Originally posted by WannaBe30
    Also the 3.5 is a lot less expensive usually and most chip tunes are for 21.5 injectors and 3.5 maf but I agree prolly no differ in performance
    I don't think you could say "most" of them are tuned that way, but rather they are available, which doesn't even matter. non-3.5" MAF tunes also exist.
      • 34844
      Originally posted by squidmaster
      http://afepower.com/shop/details_new...artno=54-10471
      I think the main draw is that the 3.5" uses a heat foil (HFM) which measures more accurately and has a wider operating range.
      For E30s I recommend people just stick with the M20 AFM unless they can get a known working and tested M30 AFM for cheap. As any AFM degrades over time, updating it with new(er) and better working hardware can be worth the price in itself.
      perhaps but does it really matter? does the timing and fuel accuracy of the DME increase along with the slightly better HFM accuracy (remember the DME is still ~1993 technology)? does the wider range benefit anything when you're unlikely to clip the stock sensor even with common bolt ons?
      • squidmaster
        • Aug 2011
        • 2666
        Eh.
        That's about the best answer.
        Definitely better for forced induction however
        • WannaBe30
          • Feb 2013
          • 295
          Biggest reason I went with it is because of price and the tube I had available
          Check the price of obd1 3" maf and then check the 3.5" you'll see
          And if this thread upsets you so much about 3.5 being better stop replying so it will disappear again
          I posted this up in November first... The first reply was less than a week ago
