What maf should I use?
  • WannaBe30
    • Feb 2013
    • 295
    In the middle of my swap and I was wondering what do y'all think about maf choices?
    S52 obd1 should I keep the stock one or is there a better option for performance?
  • mballn
    • Mar 2014
    • 10
    3.5" MAFS is a cool upgrade. that what i have on my E30 M50 swap
    • Spitfi-r
      • 132
      yup. I run a 3.5"
      It looks like you are close!
      1991 318is sold!
      1989 325=track car--S52'd
      Durango R/T for towing.
      >>>Build thread<<<
      M235i daily driver
      • WannaBe30
        • Feb 2013
        • 295
        Older pic 3.5" is in thanks
        • butters
          • 1202
          What did you guys run upstream of the 3.5" maf?
          I am putting one in mainly to use a TRM chip, and while a reducer is an easy $15 solution to adapt with my KAMotors intake, I am wondering if there is a 3.5" filter/silencer solution out there.
          I'm not willing to slap on a cone filter unless I have some sort of heat shielding.
          • squidmaster
            • Aug 2011
            • 2666
            AFE makes one. Wish KAM would do a 3.5" intake!
            • WannaBe30
              • Feb 2013
              • 295
              Squid master
              Which one from afe are you taking about
                • 34844
                hasn't it been pretty well proven by now that the 3.5" MAF doesn't really do anything? You get a gain but it's mostly because you have to get a tune with it, and you'd probably gain the same power regardless.
                it just seems silly that BMW could have gained an easy 10hp because they undersized the MAF, when we know BMW doesn't usually design stuff like that (and why bolt ons don't do much on BMW motors). It's not really any different than thinking you'll gain a bunch of power from switching from an M20 to M30 AFM which turned out to be basically nil.
                • squidmaster
                  • Aug 2011
                  • 2666
                  Originally posted by WannaBe30
                  Squid master
                  I think the main draw is that the 3.5" uses a heat foil (HFM) which measures more accurately and has a wider operating range.
                  For E30s I recommend people just stick with the M20 AFM unless they can get a known working and tested M30 AFM for cheap. As any AFM degrades over time, updating it with new(er) and better working hardware can be worth the price in itself.
                  • butters
                    • 1202
                    nando I agree, I just happened to find a TRM chip pre-owned that is designed for the 3.5" maf among other things. The maf itself is very cheap nowadays. Also I don't think I'd say that it's "proven," I haven't seen any data on the subject.
                    • butters
                      • 1202
                      meh.. the heat shield is obviously for the 540. Maybe I'll call aFe and see if they'll sell me that filter - the build-your-own filters don't appear to have an opening on the "top" like that one does.
                      • WannaBe30
                        • Feb 2013
                        • 295
                        Also the 3.5 is a lot less expensive usually and most chip tunes are for 21.5 injectors and 3.5 maf but I agree prolly no differ in performance
                        • frankie591
                          • Feb 2012
                          • 545
                          this thread is full of bad information. A 3.5" maf is completely useless. Look at the size of the throttle body and tell me how increasing the size of the tube leading to the throttle body will allow more air into the engine.
                          • butters
                            • 1202
                            Relax, none of the posts in this thread are claiming a performance gain from the 3.5" maf. The discussion is regarding plumbing after OP stated that they went ahead with a 3.5".
                            • squidmaster
                              • Aug 2011
                              • 2666
                              Sorry, they have an e36 specific one for the 3.5" maf. I just copied the first google link. Check out their site. I think Turner sells their e36 3.5" maf kit as well.
