Shifter Linkage not lining up?
  • Bmrlvr4lfe
    • May 2021
    • 39
    Hey All
    In the middle of my m52 swap on my 87 325is. We put the engine and transmission(getrag.260) in. I’m trying to line up the shifter and it looks like the linkage is not lining up. I’m using a z3 shifter, garagastic 10% dssr, condor swap bracket with new bushings. I’m having to force it up an in, looks the center point of the shifter is all the way over on the passenger side. Is this correct? Any help would be appreciated.
    ben
  • Chilezen
    I weld cats
    • Dec 2013
    • 1940
    I had this issue, and since I can cut & weld, I just welded a new stud off to the side.
    Click image for larger version Name:	54CP9kZ.jpg Views:	0 Size:	63.4 KB ID:	10041915
    It is a known issue: https://www.r3vlimited.com/board/for...question/page5
    I copied this solution from someone else: https://www.r3vlimited.com/board/for...e4#post6309835
    Currently building a badass coffee table
    Random stuff on insta @kevanromero
