Belt Size??
  • Thicc
    • Apr 2022
    • 7
    Belt Size??
    Hello
    I swapped an m50 on an e30. I have the following accessories deleted: Power steering, air conditioning, clutch fan
    The mechanic installed a belt which tight but the problem is on full throttle it slips.
    So i'm pretty sure either the belt size is wrong or something else.
    Can someone tell me the correct belt size for an m50 with those deleted?
    Sent from my SM-N950F using Tapatalk
  • 2mAn
    SeƱior Mod
    • 20989
    What are the numbers on the belt? You can get a few different belts and see if that helps... could also measure it all with a string and find the corresponding belt size that way
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • Northern
      I like cupcakes & sh!tboxes
      • 5279
      +1 for the string because even if someone posts a length for this same combo, people often don't say whether they're running the alternator idler or not and it probably changes the length by 10mm or so.
      Originally posted by priapism
      Originally posted by shameson
      • Thicc
        • Apr 2022
        • 7
        But why would someone not run an idler?
        Sorry first time I hear about this
        • Northern
          • 5279
          Seems to be a factory thing, and I have no idea why.
          Look at 11/97 build date 328is on realoem and you'll see both configs.
          https://www.realoem.com/bmw/enUS/par...BMW-328i&mg=11
          On the other hand, I guess I'm wrong about the belt length - they call for the same length belt in both configurations.
