Which MAF do I use?
  • i_build
    • Oct 2015
    • 52
    Which MAF do I use?
    M52B28 from a 96 328, 413 ECU because it was switched to OBD 1, M50 Intake Manifold... with Pink top injectors.
    I purchased a MAF that said it would work for a 92-95 328i so that it would connect to the OBD1 MAF Plug (round). Without the MAF plugged in I get a steady good idle and with it plugged in the idle is unsteady and loops.
    I did smoke test the system and there are no leaks... I'm just really confused as to how the 413 ecu with a 96 M52B28 and M50 Manifold with pink top injectors... all know how they should work together.
    The DME looks like it has the stock M50 chip in it... is that the problem?
    I'm confused and would appreciate some help.
    Thank you in advance.
  • DesertBMW
    • Aug 2011
    • 1038
    there is no 92-95 328i, and 1992 has different MAF and ecu than 93-95. Looks like you need to have top green injectors from 93-95 325i and the good known MAF from same years. Pink top injectors flow more and will be too rich with stock M50 chip.
    • i_build
      • Oct 2015
      • 52
      Yes... that's the problem. Been studying a bit on MAF scaling and a bit on the programming side for the chips that go into the 413 red label. I still have my megasquirt and 42lb delphi injectors and would have no issues setting up the injectors if I were using the megasquirt... but to do that I would have to setup everything needed to drive the coil packs (MS2E) and I am not too familiar with how to do that. I see some info on scaling and burning my own chips for motronic. I'm a software engineer so I am not scared of doing that it's just hard finding a source that will give me all the info I need.
      • i_build
        • Oct 2015
        • 52
        Does anyone have any idea as to why this topic... M52B28, OBD1, 413 DME, M50 Intake, Pink top Injector... tuning... seems to be so hard to get good info on... do most just switch back to OBD2 since OBD2 is now more easily worked with?
        • Northern
          I like cupcakes & sh!tboxes
          • 5262
          basically you're stuck burning chips or beating your head off a wall trying to get a miller war chip to work right to tune the 413.
          Xref that MAF part number vs whatever is on realoem for a '93-'95 325i
          I'd either:
          Set it up like an M50tu. Full harness/sensors/injectors/ecu. ignore the displacement difference and hope the engine sorts itself out (or buy a chip if you really want the pink tops) Or:
          Set it up like an M52, full harness/sensors/injectors/ecu. Pay for deletes/tune from someone reputable or spend time figuring out how to flash/tune/datalog with the open source MS41 stuff.
          Originally posted by priapism
          Originally posted by shameson
          • i_build
            • Oct 2015
            • 52
            Just purchased the chip burner and some chips. I also downloaded and installed Tuner Pro along with the XDF for the red label 413 ECU. I downloaded the M3 325 stock Bin and I think I saw that they came with the Pink top injectors so I was hoping that I could just burn the chip with that Bin and give it a go... I'm prolly going to have to pull my exhaust back off and add an o2 bung and install my wideband also... does that sound like a reasonable thing to start with? Not going to mess with timing or any tables just yet till I get the process down pat. I also got a UV eraser because God knows I'm going to be burning chips over and over. Not sure if there is a forum or something where people share BINs but if anyone is aware that would be greatly appreciated. You mentioned paying for a tune... I'm not trying to break any records or anything I just want a nice idle. I been driving it around and it has plenty of power for me as is... I did get the MAF but I now have a surge even without the MAF at idle and she is vacuum sealed so I am really thinking that tune is probably fueling for the stock injectors or something and it gets into some sort of fuel or timing loop or both... jumps from 700 to about 1400 and back over and over again.
