413 non-red-label. what are my options?
  • Lof8
    • Oct 2006
    • 2827
    Found out today that my s50 is coming with a non-red-label 413 dme ('95).
    I'm not messing with the injectors or afm quite yet.
    Is EWS going to be an issue with this one?
    Can I use it as-is?
    do I need a chip for it to work?
    Whos got the best chips for my application?
    Would I be better off finding a red label?
    thanks for the help. I've read the dohc thread and made lots of notes. for some reason this stuff isn't in my notes
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
  • hoveringuy
    • Dec 2005
    • 2750
    EWS will be an issue with this one. '95 silver label's have EWS, no doubt.
    You could purchase an ealier ECU or get an EWS delete chip. If you were planning on getting a chip anyway, then it's a no-brainer.
    Can I use it as-is?
    • Uber E30
      • 1409
      Silver label 413 WILL have EWS Silver label 506 ECU will not have EWS... both came with the 95 m3's. Your options consit of getting a 506 or a red 413 or keeping the silver 413 and getting a EWS delete chip. I would lean towards the red413/506 since either of those ECU's will be about the same or less then an EWS delete chip.
      As for software... hands down TRM
      -Alex
      • Lof8
        • Oct 2006
        • 2827
        perfect. thank you guys
        S50'd
        • lifeiskaos
          • 1709
          i have a silver label 413 ecu for sale if anyone is interested. as said above, if you plan on getting a chip anyways, EWS delete chips are often no more expensive. pm me!
          • Lof8
            • Oct 2006
            • 2827
            Just bought a red label for $100. Much better than a $300 chip.
            S50'd
            • dude8383
              • Jan 2005
              • 10387
              EWS delete chip is $100 the racers market.
              either way, good deal.
              • Eric Giles
                • 1068
                Actually, TRM is showing the EWS delete chip for $204.95.
                I was recently thinking about the 413 red or silver label discussion. I had kept thinking that I really just needed to concentrate on finding a red label 413 for my future S52 with OBD1 swap...but then I came to the realization that the factory chip in a 413 isn't going to have the correct tune for my application, as it would be suited for an M50.
                You are going to pay around $250 for an S52/OBD1 chip in most cases. The silver label 413's seem to sell for half of what red labels do (just from my recent searching) because they have EWS enabled. Seeing as that $250 will get you the proper S52/OBD1 chip with EWS deleted, it makes sense to just go ahead and save money on the silver label 413 DME.
                Am I correct on this, or is my lack of sleep taking over? Of course this would only apply to S50/S52 motors-not the M50.
                Eric Giles
                '20 M2 CS
                '04 M3
                '11 X5 35D
                '87 325is
                '91 325i Sport
                There are few things more expensive than a cheap BMW...
                • Uber E30
                  • 1409
                  Personally i would rather start with a non EWS platform as it leaves more options in chips and more then likley cheaper in the long run. Plus its just removing one more variable of problems that could happen.
                  -Alex
                  • dude8383
                    • Jan 2005
                    • 10387
                    DOH! I should have checked their site first. I did buy MY chip for $100 around September-ish.
                    • hoveringuy
                      • Dec 2005
                      • 2750
                      What's the difference between the 413 and the 506?? (besides the chip)
                      • Uber E30
                        • 1409
                        Someone said the 506 is more adaptive but i call BS. Im pretty sure the chip is the only difference.
                        -Alex
                        • e30_325es
                          • 1249
                          Can't you just clip a wire or something and delete ews?
                          • jrdeamicis
                            • Nov 2008
                            • 956
                            The EWS wire is pin 66 on the x6000 connector. Solid green wire.
                            Past Car : E30 S50 6 Speed 5 Lug 3.73
                            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                            ___________________________________________
                            BNB Designs
                            Engine Swaps, Fabrication, Innovation, General Repair
                            Richmond CA
                            Julian 848-248-8029
                            • e30_325es
                              • 1249
                              x6000 is the ecu connector, right? thank you.
