MIKe30's 11:1 cammed OBD2 s52 build
  • dude8383
    • Jan 2005
    • 10387
    #226
    Oh my jebus your car sounds dope. I gotta throw my exhaust one the car, its too quiet! I ended up purchasing a Remus E36 catback...haven't had the time to install it though :(
    • SwiftE30
      • Jun 2010
      • 998
      #227
      Originally posted by sharky
      Sounds awesome, a little thread jack, I am doing a S52 swap and have all the EWS stuff but would like to delete the rear O2's, EGR valve and secondary air pump as well as the EWS just for sake of ease and less things to break. Are there any things that I need to get welded or plugged up when I remove the secondary air system? Who has some really good tunes for these?
      What is the benefit of deleting the rear o2 sensors and the ews? I've heard mixed opinions on whether or not to keep the ews for tuning purposes.
      1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
      • flyboyx
        • 8371
        #228
        the sole function of ews is that it is a complicated switch that keeps your car from getting stolen. it really doesn't have anything to do with the engine tune. the o2 sensors are another story. when we swap later model engines into e30's, it is common to delete various components because of cost and simplicity. it may or may not be a good idea, but it is often done because it saves time and money and complexity.
        Gigitty Gigitty!!!!
        • SwiftE30
          • Jun 2010
          • 998
          #229
          Is deleting the o2 sensors just cutting them out of the wiring harness? or is it done when you have the car tuned or something? And isnt it bettter to run more o2 sensors because you will have more control/info on what mixture is running through your car?
            • 34844
            #230
            the after cat O2 is for emissions only, it doesn't affect performance. Also if you are converting to ODB1, it's not used at all.
