MIKe30's 11:1 cammed OBD2 s52 build
  • So Live
    • 2512
    #181
    tires = too small
    Sick build though dude!!!!
    I want vids + dyno graphs stat!
    -Chris
    • z31maniac
      • 17566
      #182
      When is this bad bitch doing on the dyno?
      www.gutenparts.com
      • MIKe30
        • Sep 2006
        • 2334
        #183
        thanks guys. Going to pick her up from the shop in a few minutes. She had the midpipe put on and o2 bungs welded in. Don't know if I mentioned in this thread, but I fixed the diagnostic port issue and can now use my peake tool. Just before dropping her off at the shop I scanned it after a drive up and down my street open headers, lots of codes thrown.
        I reset it and trailered her to the shop so I wouldnt drive it open headers. She's not running quite right yet, will find out how bad it is and what she needs when i bring her home tonight.
        It'll be some buttoning up, making sure she's running like a top over the weekend (i suspect tps and crank sensor issues). Off to exhuast shop to get catback on (needs fabrication due to e36 exhaust, and euro midsection tubing being much larger than stromung catback tubing).
        Then it's tidy up wiring. Coilovers should be here by then. Been trying to get Jonathan to sell me his staggered m-systems but he's not budging. We'll see. Maybe gold bbs?
        • ZM Blue Devil
          • Dec 2006
          • 13836
          #184
          I want to see this bad girl at Guten this weekend. Stop lifting and get to work.
          Levent
          %20levent@gutenparts.com
          Ladies:
          • MIKe30
            • Sep 2006
            • 2334
            #185
            With the exception of one week, havent seen a gym in 2 months because of this little devil!!
            edit: might call her the white devil... hmm. anybody have a good name? maybe white money pit... fml.
            • Wh33lhop
              • 11705
              #186
              Originally posted by MIKe30
              I'm just quoting this so it won't be buried as quickly. Holy crap.
              Congrats man, thing sounds MEAN.
              paint sucks
              • MIKe30
                • Sep 2006
                • 2334
                #187
                thanks again guys. Drove her for 15 miles last night. HOLY SHIT ITS FUN!!! :):):)
                I can't wait till she's completely broken in and running perfect.
                Can anybody explain these codes? Keep in mind I don't believe they were cleared before installing the new o2 sensors. They were cleared, but then it was driven off a trailor, into the lot, and then into the garage onto the lift. Sensors then installed.
                Anyway, here's the list of codes thrown:
                table 11,
                codes
                37 - PreCat o2 sensor heater, Cyl #4-6
                19 - PreCat o2 sensor heater, Cyl #1-3
                08 - Air Mass Sensor
                32 - EVAP System Running Losses Valve
                D6 - Vehicle speed signal not present
                Don't know what the "sensor heater" part is, but should they go away after a reset since the o2 sensors are new?
                Air Mass - this becuase my filter is directly on the air mass and there's no bracket securing the position of everything?
                Not sure what to do with the EVAP, isn't that for my charcoal canister? yea, I deleted it :embarrassed:
                Vehicle speed sensor - motherfucker, gonna have to read the million threads that came up last 2 weeks about this shit. Thought it would have been taken care of when my harness was done, guess not.
                Sounded so good with just the headers and midpipe. Has cats and resonator, sounded sooo good!! Can't wait till she's running perfect. Couldn't stop smiling/giggling like a school girl! :mrgreen:
                Hope she runs and lasts a long time **knock on wood**
                • SamE30e
                  • Sep 2007
                  • 4319
                  #188
                  It's possible that they'll go away, but it could be a wiring issue. Check the o2 sensor heater relay to make sure they have power when the ignition is on.
                  And the speed signal, another wiring issue possibly, should be wire going from the harness to the ECU for road speed. There's a thread on here somewhere about it.
                  1985 325e 2.8 Turbo VEMS
                  • MIKe30
                    • Sep 2006
                    • 2334
                    #189
                    Never even heard of a sensor heater relay, let alone what it is. Time to search search...
                    • etxxz
                      • Feb 2006
                      • 2085
                      #190
                      i'm glad that you got the diagnostics tool working. what was the problem???
                      The O2 sensors have two circuits. A heater, and the Catalyst that generates potential for dme signal. If they are new, I would think resetting the dme/codes would do it.
                      The vehicle speed signal. In e36’s it comes from the differential.. much like ours, goes to the cluster and from the cluster to the DME. Does your tach and Odometer work? If so are you rpm limited at 5k(or 6k?)?
                      No idea on evap (I thought you deleted it) and air mass codes.
                      No more e30s for me.
                      88 black BMW OBDII 332is dedicated track [sold]
                      88 BMW OBDII bronzit 332is [RIP 03/08]
                      91 BMW 325i [sold]
                      86 Corolla 'Ae86' HB 20v trd [sold]
                      http://youtube.com/watch?v=pTj7Hn9v5Rs
                      • hoveringuy
                        • Dec 2005
                        • 2729
                        #191
                        Congrats on getting it running!
                        EVAP.. this one's easy. When you deleted it you didn't put a load resistor in place of the valve. The ECU MOSFETs are smart enough to know that they should see a cetain amount of current when they turn the purge valve on. If they don't see that minimum threshold current, they signal a fault.
                        You can fool the MOSFET by getting a 33Ohm power resistor at Rat Shack. It's a big ceramic resistor. 47Ohm would be fine, too.
                        • MIKe30
                          • Sep 2006
                          • 2334
                          #192
                          Wish you would've been able to help a little more, but got lucky and flyboyxx helped me out. One of the pins the peak tool uses was not getting power (pin 14 green/white). You can either run that green/white wire through the harness to a 10 amp fused power source, or do like I did and pull back the diagnostic plug cover and splice the 16 power wire to the 14 green/white wire. (actually spliced mine in the main section of the harness, just followed the 14/16 wire down the line).
                          Don't know if it's limited, car keeps stalling - sometimes holds an idle other times stalls. Guess I have to run a wire from the cluster to the dme? Anyway to do it in the engine bay instead of taking out the cluster and running a new line? Old line should still be there somewhere right? At least up to the harness. :???:
                          Nice. Thanks, I think I remember you mentioning this in another (maybe your?) thread. The EVAP valve is electronic right? Don't know if I'm right, but I think it's the one coming right off the injector harness?? I have the valve plugged in but nothings hooked up to the valve.
                          I really wonder why my MAF is throwing a code... :(
                          • White325is
                            • Oct 2006
                            • 5947
                            #193
                            The wire for the cluster is your speed sensor. Its the single pin one with the green cap. its sending your car into "limp" mode.
                            PM EricT and he can tell you what one it is. Unless someone here knows the pin number. I had the same problem with mine as did Reef.
                            • MIKe30
                              • Sep 2006
                              • 2334
                              #194
                              Thanks Mike. Did it make your car stall a lot? Just started searching speed sensor threads, this one popped up and highlighted your post ha
                              • White325is
                                • Oct 2006
                                • 5947
                                #195
                                It made it cut out and if I would get on it I couldnt really rev above 3 grand. But if I just got on it slow and normal it was fine and I could drive it like a granny.
                                EDIT: Looks like speed sensor is pin 14 and its a small black wire white stripe. I have to go look. But it should be the same on both sides.
                                You could be able to get a new evap can from the auto zone for a few dollars. then just grab some hose, clamps and a valve from an M20 should work fine.
