MIKe30's 11:1 cammed OBD2 s52 build
yeh, when i did my m20 flywheel swap on my m42 i used two sockets and electrical tape :)
after that experience i promised myself that i would never do a clutch job without one, the alignment tool makes it MUCH easier.
shit if you can't get one, i can lend it to you.IG: deniso_nsi Leave me feedback here
That and alignment tools are cheap. I had a local shop custom build a clutch for the M20 flywheel, I think they charged me $4.95 for the alignment tool?Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Great thread. Subscribed. Good luck with the build.Last edited by C-T; 07-02-2009, 11:05 PM.Comment
Thanks guys, but was only asking about the alignment tool since I had forgotten to add it to the first order. Was going to add it to this second order I just placed, but took it off since pelican was going to charge me shipping on it because it was coming from a different warehouse - even though my total was $300+ (with stated free shipping anything $75+). The $3 extra dollars isnt a big deal but its the damn point. I'm going to call monday and have them include it with free shipping or I'll just get it somewhere else.
Anyway, bought this last night, should be here friday. Then again, of the 4 packages that were supposed to arrive this past thursday the 2nd, only 3 arrived - last will show up monday. The list:
(In Process)
07-11-9-901-023-M9
Pressure Plate Bolt, BMW E30 All, (1992-99), Each
Brand: Genuine BMW
6
$1.00
$6.00(In Process)
11-28-1-469-266-M21
Belt for Alternator/Water Pump, 6K X 1555, 325i/is/iC (from 09/91), 323i/is/iC (1996-99), 328i/is/iC (1996-99), M3 (1995-99), Each. Supercedes 11-28-1-437-929
Brand: Contitech
1
$15.25
$15.25(In Process)
11-51-7-527-799-M58
Water Pump (uses plastic impeller), 323i/is/iC (1998-99), 325i/is/iC (1992-95), 328i/is/iC (1996-99), M3 (1995-99), Each
Brand: OEM
1
$82.00
$82.00(In Process)
11-53-1-466-174-75-M2
Thermostat, 75 Degrees, 525i (With M20 Engine)(1989-90), 535i (1989-92), 325/e/es/i/is/iC,iX (9/85-91)
1
$25.50
$25.50(In Process)
11-53-1-722-531-M200
Thermostat Cover - Aluminum (also use one 11-53-1-740-437-M17 gasket), 525i Sedan/Touring (With M50 Engine, 1991-95)
Brand: MTC
1
$10.75
$10.75(In Process)
17-11-1-469-176-M6
Radiator, For Cars With Manual Trans, 318i/is/iC (1991)
Brand: Behr
1
$157.25
$157.25(In Process)
17-11-1-742-232-M148
Radiator Cap, 318i/is/iC (1991), 325/i/is/iC/iX (09/87-91)
Brand: Reutter
1
$12.25
$12.25(In Process)
23-71-1-175-939-M61
Transmission Mount, Manual, (2 per car, sold per each) 325/e/es/i/is/iC/iX (thru 1991), Each
Brand: Meistersatz
2
$7.25
$14.50(In Process)
33-11-1-210-405-M9
Gasket for Differential Cover, BMW E30 325/e/es/i/is/iC/iX, M3, Each
Brand: Genuine BMW
1
$3.00
$3.00Shipping Method:Ground Delivery
Subtotal:$326.50Shipping:$0.00Taxes:No Taxes Charged Total price:$326.50
It was. I had magnificent TQ and more than acceptable whp considering I was running the stock headers, which choke out my engine a bit when it comes to ultimate high RPM power, but the bigger TQ number suited my E36 better as it was only street driven.
Front 5-lug struts and wheels are on, right now has old rotors and no brakes - looks like they will be getting redone tomorrow and on by tomorrow night hopefully. Began removing rear trailing arms to swap in the M one's, but rear axle nuts are being stubborn even with 30mm socket. Think I need a 6pt. Think I'm just going to remove axles from diff and of the 4 axles I have on 3 sets of trailing arms, see which two I can get off later and put them on the M arms. Rear rotors/brakes are in, will have calipers when I get the others done. Ball is finally getting rolling.Comment
i would have bought a metal impeller water pump but everything else looks good!
how bought some progress pics?IG: deniso_nsi Leave me feedback here
I'll try to get some today if I rememberComment
Front 5-lug on, calipers for front and rear being sprayed today. Rear rotors are in, front will be in tomorrow. Hoping to get the M trailing arms on today, then bolt calipers/brakes on tomorrow after work.
New question: I'm keeping obd2, I plan on buying an over the counter harness adapter by someone like a treehouse racing and having my rear o2 sensors, secondary air pump, and ews deleted through software tune. Anyone see a reason why this would NOT work?Comment
I am around 13G's deep. And thats with already having the motor and getting my tranny on the cheap :)Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
No more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold]
http://youtube.com/watch?v=pTj7Hn9v5RsComment
bimmerworld will do your DME. iirc they quote me $200 for what you're asking + something like $75 for a mild tune (i/h/e). the harness adapter i don't know how OTC it would be. i just made one w/ ewsII for a fellow r3v'er. have made both of my cars. maybe you'll want to pm me and we'll work on the specs... oor go to my obdII thread and make your own
and to those talking about money dumped into these pits... really, I'm going to throw up if i do the numbers in my head again.Comment
lol..like none of you have ever seen a MasterCard commercial...
exactly. Priceless.
3rd e30; 8-10k and counting :giggle:No more e30s for me.
91 BMW 325i [sold]
11:1 forged CP pistons and stock rods. From what I understand these stock rods are plenty strong for upwards or 700whp (well something insanely high like that, don't quote me on the exact number)
