MIKe30's 11:1 cammed OBD2 s52 build
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image. -
[QUOTE=MIKe30;1584168]11:1 forged CP pistons and stock rods. From what I understand these stock rods are plenty strong for upwards or 700whp (well something insanely high like that, don't quote me on the exact number)[QUOTE]
Thanks, only curious because i am using Wiseco .025 overbore pistons right now for my rebuild from Turner with stock rods and everything else. Will upgrade to cams later...not sure what my compression will be though.Comment
I just did a OBD II S52 with EWS in my M3, The wiring is not to bad. I would be happy to share my diagrams with you. Just shoot me a PM.Comment
As of today, both rear m3 trailing arms are now on. Had trouble removing passenger side ebrake cable, absolutely just wont come off (same goes for rotor allen screw). Looks like I may have to cut the cable and fish in a new one if I want to keep my ebrake bits.
Rear axles are not on either, have to get them off the old trailing arms. They didnt want to budge with a 30mm socket I had, so I took them off at the diff. Don't know how I'm going to remove that axle nut, but I'm going to have to figure it out. At least the car is supporting its own weight now, and I can tow it to my house if need be. Waiting on calipers to finish being sprayed/rebuilt. Anyway, it's some progress. Slow but steady.Comment
keep them coming... How is Yana doing?sigpic
Levent
%20levent@gutenparts.com
Ladies:
1998 E36 m3/4/5 1988 325i 1989 325iTComment
Started installing the rack, first question is did you guys use spacers on the two bolts to subframe holding rack in place, or just bend tabs till rack fits snug and secure then bolt up? Secondly, seems like there is A LOT of play in my tie tods compared to old rack I just removed. Tie rods almost swing freely and I can even rotate them 360 deg whereas I couldn't eve come close to doing that with my e30 rack. Sound like I have bad inners??Comment
Rotation isn't necessarily a bad thing. Backlash is. Can you tug or push on the tierod and get movement? If so, toss them. You should be able to use regular e30 tie rods, if you want to save the old tie rods.'89 325i track sloot
'01 530i daily
-EnginerdComment
