Idle fix
  • 416stroker
    • May 2008
    • 2448
    Idle fix
    How should I go about raising up the Idle on my m50? I dont have my chiltons infront of me so I cant look it up but its driving me nuts. My car idles at about 600rpm but with the a/c on it idles at 500 and its vibrates like a motherfucker. shouldnt Idle be at like 750-800 when its operating normally?
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
  • hoveringuy
    • Dec 2005
    • 2752
    600 is normal idle. I had TRM raise mine to 900 because of my lightened flywheel, but you still shouldn't have it that low with the air. Do you have the A/C signal going to the ECU? That should raise it with A/C engaged.
    • matt
      • 3732
      Stock idle speed is 650rpm. The only way to raise it is with software.
      Connecting your compressor signal will help, AC on idle speed is 770.
      • 416stroker
        • May 2008
        • 2448
        Ok cool Im gonna have to hook that. Back to the etm.
        So I shouldn't fuck with that screw on the tb?
        84 318I Delphin RIP
        89 325 Alpineweiss
        • matt
          • 3732
          Definitely do not fuck with the screw on the TB.
          • etxxz
            • Feb 2006
            • 2085
            ^^ +1
            look on the ETMs. there is a wire (the one that engages your compressor) that you have to splice to your DME.
            No more e30s for me.
            88 black BMW OBDII 332is dedicated track [sold]
            88 BMW OBDII bronzit 332is [RIP 03/08]
            91 BMW 325i [sold]
            86 Corolla 'Ae86' HB 20v trd [sold]
            http://youtube.com/watch?v=pTj7Hn9v5Rs
            • rneedham1979
              • Jul 2008
              • 852
              Where can i find a DIY for hooking up the AC compressor signal?
              Thanks!
              Turbo E30
              Roadkill 80lb 93 octane OBDI tune
              BavSol Cylinder Head
              Stock S50 in. cam Schrick ex. cam
              Otis' tubular T4 manifold
              Oringed 87mm S52, Eagle rods and 8.5:1 CP pistons.
              GT4094r w/Batmowheel Impeller
              614whp@17.5psi, 100 Oct
              690whp@21psi, 100 Oct
              801whp@27psi, 110 URT
              Old: 1/4 mile: 10.91@144.38 (636whp)
              New: ?
              http://www.youtube.com/watch?v=L_f7fUVqblI
              • 416stroker
                • May 2008
                • 2448
                Just curious what happens if you fuck with the screw. It throws the tps out of wack?
                Edit I want to be able to explain it to my dad that was his advice and I said I dont think I should.
                84 318I Delphin RIP
                89 325 Alpineweiss
                • matt
                  • 3732
                  Yes, it throws the TPS out, but more importantly, the ECU will be trying to pull the idle down to the RPM it wants it at, and if it can't it will be unhappy.
                  • 416stroker
                    • May 2008
                    • 2448
                    Ok thanks for that information.
                    84 318I Delphin RIP
                    89 325 Alpineweiss
