Wiring help Please.
  • BMW_TUNER
    • Jul 2006
    • 1386
    Wiring help Please.
    My borther and I where trying to get my S50 all prewired today to install it but we ran into a bit of a problem. My harness is in great shape but how can I be sure that I am plugging all of the connectors under the intake manifold into the correct plugs? Is there a diagram or a trick that you guys are using? I just dont like trial and error.
    Thanks in advance for any help.
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
  • e30s52
    • Oct 2007
    • 5235
    Color code on the wires.
    www.gutenparts.com
    • BMW_TUNER
      • Jul 2006
      • 1386
      The only diagram I can find does not lay out the wire color. Does anyone have. Good one they can post up. I need to figure out what color the wires are for
      knock sensors
      tps
      coolant
      vanos
      IACV
      crankshaft position
      evap
      IAT
      oil pressure
      and any other two or three wire little bastards that go under the intake manifold.
      • booostit
        • Jul 2009
        • 224
        try alldata?
        • hoveringuy
          • Dec 2005
          • 2722
          The only way to do it, foolproof and 100%, is to check continuity between the plug and the different pins on the ECU connector. I don't have the reference to the pinout on the ECU, but if pin 45 is "knock 1-3" check all the plugs until one beeps, that's the plug for the forward knock sensor.
          BTW, both knock sensors have the same wire colors so you HAVE to do this!
          • BMW_TUNER
            • Jul 2006
            • 1386
            I found a diagram with color codes but they made no sense. Then I found the manic decoder ring.
            RT =red
            RS=pink
            GE=yellow
            SW=black
            TR=clear
            • e30s50dan
              • Nov 2008
              • 2076
              NASA
              BMWCCA member
              PCA member 25yrs
              1991 318IS slick top
              1997 M3 sedan
              2001 325CI DD
              “whoever turns the wheel the least, wins"
              • BMW_TUNER
                • Jul 2006
                • 1386
                Traced each one to the Main connector at the DME. I will make a graph for future reference.
                • BMW_TUNER
                  • Jul 2006
                  • 1386
                  What is the plug next to the oxy sensor?
                  • FredK
                    • 14761
                    No tricks, just read the appropriate page in the Bentley manual or the BMW ETM.
                    oil pressure sensor BRN/GRN or BRN/GRY
                    front coolant temperature sensor (ECU) BRN/RED BRN
                    rear coolant temperature sensor (Gauge Sensor) BRN/YEL BRN/VIO
                    crank position sensor YEL
                    cam position sensor YEL RED/WHT BRN/ORG
                    VANOS solenoid RED/WHT GRN/BLU
                    knock sensor, 1-3 BLK NCA DME PIN 70
                    knock sensor, 4-6 BLK NCA DME PIN 69
                    throttle position sensor (TPS) BRN BRN/BLK RED/YEL
                    intake air temperature (IAT) sensor BRN GRY
                    idle control valve (ICV) WHT/YEL RED/WHT WHT/GRN
                    Evaporative emissions valve BRN RED/WHT
                    • BMW_TUNER
                      • Jul 2006
                      • 1386
                      Thanks for that I will double check everything. So does anyone know what the one next to the oxy does? Is it a back up switch?
                      • FredK
                        • 14761
                        yes
                        I just tied it off and used the stock E30 backup wiring with the E30 backup switch in an E36 transmission.
