DME for an S50
  • 91Saleen#15
    • Mar 2006
    • 230
    DME for an S50
    I just finished an S50 swap into a 318is, following info in this forum. My 95 M3 DME wouldn't allow the engine to start presumably because of the EWS, so I am currently running it with a DME from a 93 525i. Long term, I plan on getting a chip that will allow me to use the DME from the M3, but short term, I need something so I can get it to the muffler shop and the alignment shop. Can this cause any serious problems?
    Richard
  • hoveringuy
    • Dec 2005
    • 2752
    It should start and run on that, although the chip is far from optimal. As long as you don't get on the gas hard I don't think it will hurt anything.
    • M-technik-3
      • 18946
      No mention of what ecu you have. 413 with proper chip is what most use.
        • 37833
        Swap the chips.
        Grover Beach, California
        BimmerHeads.com
        • 91Saleen#15
          • Mar 2006
          • 230
          My 93 525i DME is a red label 413. My 95 M3 DME is a silver label 413. The engine starts, idles well, revs without hesitation, and had gobs of power the one time that I got on it. The injectors of both the 2.5l engine and the 3.0 liter engine are green. I assume that means they are of the same size. If the injectors are the same capacity, then I am hoping the DME will correctly measure the fuel. Tomorrow I will connect a wide band air/fuel meter to test this theory.
          Richard
          • Uber E30
            • 1409
            you have the right DME you just need a chip for it... i suggest TRM
            -Alex
            • matt
              • 3732
              Fuel will be close. Spark may not be. I would avoid high load until you get the right chip.
              Let me know if I can help.
              • 2002maniac
                • 4260
                I have a stock S50 chip (it's jay's actually) without EWS. From a '94 production M3.
                I'll look for it.
                I wholeheartedly recommend TRM though. We put one of their chips in Jay's car and it runs like a top.
                • dougsic
                  • Jun 2006
                  • 284
                  I had a silver label DME that took a dump. Replaced with a red label DME from a non m car and my car started and idled. Swapped the chips and my car now runs the same with red label as it did with silver label.
                  Go figure.
