MAZUR's E30 S50 Turbo Build
  • mazur
    • Jan 2006
    • 731
    Since I am nearing completion on my custom turbo build, I felt like it was finally time to begin my own build thread. You'll notice it's sort of a budget build, like one you'd expect from a college student :)
    I also thought it’d be fun to start from the beginning starting with my first car.
    As some might remember, I used to sport an E36 M3 in my sig. Well, just over two years ago, I had let my friend drive it on a curvy mountain road here in Phoenix, which lead to him driving us off the side of the road and flipping the car :shifty. Well, to make a long story short, I parted the whole car out, bought an E30 and transplanted the drivetrain.
    Here’s a graph of the power it made with stock cams.
    Sometime after I began getting bored with the power output and my long time thirst to own a turbo’d vehicle, I slowly began piecing together a custom kit looking for the best deals I could find to save as much as I could, without cheaping out too much.
    One of the first things I bought was my turbo which I got through my friend Mitch (Either Mr. Deagle or Noscoe30 on this forum). Specs are as follows: Garret, T04S compressor housing with GT35 wheel, .82 A/R T31 turbine housing with Stage 5 wheel…and that sweet MODE compressor nut :)
    I later on decided to paint the turbine housing with black VHT and baked it.
    Sometime after that I got myself an Ebay intercooler with a 18’’x12’’x3’’ core, which I painted with radiator paint.
    I also got these sweet turbo feed and drain flanges from Function7 made out of 7075 aluminum.
    Anyways, once I got the turbo, it was time to start designing a manifold in CAD. My reasoning for doing this was simple; create a decent manifold that will fit in the confines of my engine bay, which would at the same time make the fabrication easier and less costly since I would know exactly which bends I would need to buy and how many.
    First things first, positioning the turbo in the engine bay to get measurements for flange placement with my handy hockey stick.
    Once I had that I was able to begin my design, and this is what I came up with.
    And here's just a cool shot of the Synapse wastegate internals from when I made it for a final project in my CAD class.
    To make the collector, I took the pipes I had made in CAD and spent several hours figuring out how to unwrap them properly. Once I figured that out, I printed out the templates, wrapped them around my pipes and traced out the cuts with a marker. I then took them to school and used a bandsaw to make my cuts.
    Since I have never welded before I took the flange to my buddy Mitch to have him weld it for me. Once I had my collector complete it was time to whip out my hockey stick again and dangle my turbo with the collector attached in my engine bay so that I could tack some steel rods from the collector to the head flange.
    I then borrowed a friends welder and chop sway and began tacking my very first manifold together.
    And to my relief it actually came out quite well and fit in the engine bay the way I had planned it. Here it is mounted on a junk head.
    Here’s the finished product after Mitch welded it all together and after some VHT paint and installed in the car. Final cost was about $300.
    And here with the Synapse WG attached. And yes, I am going to leave it dumped to atmo. :D
    Soon after the manifold was completed, I mounted the turbo up and began fabricating my first exhaust system. ALL of my welding experience is in this exhaust, so be gentle with me ;)
    Here’s a shot of the downpipe, and then of it later installed in the car after some VHT. You’ll notice I’m getting my oil feed from the VANOS banjo bolt. Just temporary till I install my oil cooler cap.
    Here’s a shot of the resonator I got. A whopping 30’’ long! Oh, and the cat that I’m sharing with a friend for emissions because we are cheap asses, LOL.
    For a muffler, I got a Borla Pro XS muffler. I then took a U-bend and made a nice simple pair of 3’’ tips and gave it some VHT…man I love that stuff, haha. Forget the sloppy welds…the welder was acting up and wasn’t giving consistent amperage…no one will see it anyway. :rolleyes
    For the oil drain, I opted to go to the drain plug location since the turbo so high up anyway. I used a -8 adapter since that was the largest size.
    Since I have an E30, I have the legacy of routing the charge piping underneath the headlights.
    Therefore this is all the charge piping that I require.
    I was originally going to use a Synapse blow-off valve, but Mitch gave me a deal on his MODE valves that I couldn’t refuse. And since they work on the same concept of having no diaphragm, they are very responsive. I’m using two to be sure to expel enough air not to create any surge.
  • mazur
    • Jan 2006
    • 731
    For engine management, I opted to go with AEM and got myself a 30-1050 box. I took an old DME connector and made it plug and play. For CDI I used the Twinfire from AEM. I know it has a bad rep, but I have had it on my stock DME for about 5,000 miles and several thousand more on the AEM and have not ran into any issues yet, and I bought it used.
    For a wideband I'm using AFX. In this pic you can see the AFX unit mounted just above the radio below my gauges. Gauges are Prosports giving my oil pressure, temperature, and water temp. I don't see the need in a boost gauge, so I'm not running one. And yes I know I have a long shifter, but it makes shifting at the track oh so nice :alright
    At some point I came across a .140’’ MLS gasket for a great deal I couldn’t pass up, so I bought it thinking I may install it down the road if I feel like I need more power. Well, after blowing a headgasket on the track about four months ago, I decided that this was an opportune time to install it. (I’m not sure why I blew a gasket. It was on the third 20 minute session near the end. I just remember temps getting a little hotter than before then later temp had sky rocketed…gasket broke apart at water jacket around cylinder 6)
    So off came the valve cover….mmm, shiny :)
    Off with the head…hmm, not too bad for some 60k miles.
    And of to Mitch’s machine shop to get resurfaced.
    Then of course some copper spray to help out with the sealing. ARP2000’s were also used.
    As a point of interest, with nothing else changed besides the headgasket, the car pulled similarly, even with reduction of the CR from 10.5:1 to somewhere around 9:1.
    Well, that’s about it for now. All I really have left to do to make her ready to drive is to run the vacuum lines and source another 90* silicone bend. So next week should be the week I am FINALLY boosted!! Can’t WAIT! :D
    • Miasma
      • Apr 2007
      • 2009
      Nice build, Should be a rocket.
        • 37833
        Awesome thread, looking forward to updates.
        How could you not see a need for a boost gauge though, I don't understand that at all...
        Grover Beach, California
        BimmerHeads.com
        • Spaz
          Crazy Canuck
          • 2276
          Nice build dude, those internals look nice and clean :)
          Cam .W '91 325is
          Spaz's 1991 Alpine White???? S52 Build Thread...
          • FredK
            • 14762
            Mitch = Mr Deagle? If so, I miss that fella.
            Sweet build.
            • paulkeith
              • Apr 2009
              • 146
              i love when people wait a while to start a build thread so us junkies get a huge project fix all at once, haha
              sweet stuff.
              Not sure that painting the IC was a good idea....any idea what kind of affect that'll have on its heat transfer capability? I mean, I realize you used radiator paint which probably takes that into consideration, but since intercoolers are air/air they're already more sensitive to things like that. Thoughts?
              Paul
              pull: '02 F-250 7.3L 6SPD 4x4, Chipped, Straightpiped, BFG MTKM2.
              turn: empty stable. lame.
              • e30s52
                • Oct 2007
                • 5235
                Wow this is really cool. You will have to let me know when you are done so I can come see it.
                www.gutenparts.com
                • e30polak
                  • 6136
                  POLAKS FTMFW!!!! :hitler:
                  That's a sick build bro! You've got some skills there, I'm very impressed with that manifold! :woowoo:
                  Traction = what's that? :p
                  Planning on flaring and getting some beefy stickiness in the back???
                  Mad props, can't wait to see the results! :D
                  INSTAGRAM: @UNDR8D_EMPIRE
                  • DEV0 E30
                    • Oct 2004
                    • 8903
                    Looking good man.
                    • shiboujin
                      • Feb 2006
                      • 2791
                      looks pretty good so far. Altho Cometic recommends a full on dry application for best sealing. I had bad luck with copper spray.
                      Also, I do NOT like that oil drain at all. It'll back up into the turbo and coke up. Might not hurt now but might kill the turbo in the long run.
                      • lifeiskaos
                        • 1709
                        ehh... it'll be fine
                        although i agree the MLS should be dry
                        • Tchao
                          • Apr 2007
                          • 223
                          How is it gonna back up to the turbo!?! Lol
                          It's a top mount... Last time I checked oil doesn't flow up. The volume in the hose length is much more then needed.
                          Richard is part of the AZ crew, we don't fool around. ;)
                          • shiboujin
                            • Feb 2006
                            • 2791
                            Eh I doubt it'll stop up but I'd rather tap above the oil line.
                            • mazur
                              • Jan 2006
                              • 731
                              sweet stuff.
                              Paul
                              The can it actually helps with heat transfer. Go figure..
                              Sweet build.
                              Yup, that's him. Thanks.
                              Well, think about it. These are my reasons:
                              1. I have boost cut
                              2. I have the AEM turn on my CEL at whatever pressure I want as another precaution
                              3. If I really want to see what my boost threshold looks like I can just datalog it.
                              I just don't see the need for it. I rather pay more attention to my wideband.;)
                              Well, I already run 245's all around, but I'll worry about sticky tires when I am on the track :)
