Cooling Fan Solution for 24V running A/C
  • dude8383
    • Jan 2005
    • 10387
    So I have finally found and installed my solution to cooling a 24V E30.
    I chose this particular setup because I will be installing A/C and from what I've seen, few fan's are narrow enough to fit behind the radiator. I wanted to find something that would obviously fit and withstand the heat while sitting in traffic.
    FF Dynamics makes some seriously high quality fans, I read about them on several Muscle car forums. I ended up purchasing their 12" fan.
    http://ffdynamics.com/FFD12B.html - setup as a puller.
    Rated at 1500 CFM
    This unit fits pretty darn close on the 318is radiator but leaves enough room to install the compressor. I got the chance to test it out today and it does the job quite well.
    Now I wanted to be sure that I would have absolutely no problems overheating once I do install the compressor. I decided to change my aux fan as well. I purchased a 16" Spal fan.
    http://www.a1electric.com/Merchant2/..._Code=30102047 - setup as a pusher.
    Rated at 2360 CFM
    Its a bit loud, I'd say just as loud as the stock aux fan, but again gets the job done.
    So the way I have it setup is, the smaller 12" fan turns on when temp hits the 1/2 mark on temp guage. The high speed aux fan kicks on when temp reaches 3/4 mark. Once it does hit 3/4 the fan cools the car pretty quickly and shuts off after it comes back down to 1/2. The smaller 12" fan does not shut off at any point.
    I'll try to get some pics of everything mounted so that you guys see the clearances. I will try to get the compressor mounted tomorrow.
    • 37833
    Why is your regular fan set to come on so early? It should only need to run at low speeds or idle most of the time.
    Grover Beach, California
    BimmerHeads.com
    • zav3n
      Curious George!
      • Mar 2007
      • 223
      mines really close... spal ftw
      • dude8383
        • Jan 2005
        • 10387
        whoops that was a typo, it comes at the 1/2 mark.
        • dude8383
          • Jan 2005
          • 10387
          what size is that? you kept a/c as well?
          • zav3n
            Curious George!
            • Mar 2007
            • 223
            14' i think.... ya armen at TNG is making custom ac lines but other than that its all in.
            • hoveringuy
              • Dec 2005
              • 2744
              What are you guys using for fan controllers? (are you using fan controllers?)
              • z31maniac
                • 17566
                Im going with MCoupe radiator and fuck wiring up a fan solution like a few of my E36 buddies 'round these parts have done.
                www.gutenparts.com
                  • 37833
                  Mine runs off the stock wiring and a low temp oem radiator sensor.
                  BimmerHeads.com
                  • dude8383
                    • Jan 2005
                    • 10387
                    werd.
                    my aux runs of the t-stat thats in the radiator and the 12" is running of another t-stat thats on the upper coolant hose.
                    i'll snap some pics in a few, need to cool of with some a/c in the house first. its HOT outside.
                    • dude8383
                      • Jan 2005
                      • 10387
                      pardon the not so clean engine bay, i was bleeding the cooling system and that crap gets everywhere. the wiring is pretty f'in ugly too so that will be addressed over the weekend, i just wanted to get everything hooked up to make sure it works :)
                      pics:
                      • EightiesBaby
                        • Jul 2008
                        • 268
                        looks purrty
                        Pardon my ignorance on this subject, but you had to delete your fan clutch for this mod to work correct?
                        • dude8383
                          • Jan 2005
                          • 10387
                          Originally posted by EightiesBaby
                          looks purrty
                          well SOME people can fit the clutch fan, in my case there is no room for it!
                          • EightiesBaby
                            • Jul 2008
                            • 268
                            so those people would be running THREE fans?
                            • dude8383
                              • Jan 2005
                              • 10387
                              oh hell no man. you only have two choices for the radiator side, clutch fan or electric fan.
