Which 24v should I use for a swap?
  • JGood
    • Jan 2004
    • 7959
    OBD-I S52
    Or don't fucking bother with it.
    I don't know about that. I did my m50 swap in 4 days, and it cost a total of -$50 (after selling old parts). If you find good deals you can do this shit CHEAP. And it's easy.
    My car now runs great. Gained over 1 second and 6 mph in the 1/4 mile over my 500lb lighter m20 track car. The car is light years more driveable and fun then my m20 car. It gets 5mpg better gas mileage. And there is virtually no maintenance. And no more ridiculous valve tapping.
    IMO, do a cheap m50 or go LS1. If you are going to spend thousands of dollars you might as well get more then 240whp. I can get 190-200whp with a set of M3 cams. My firiends OBD-I s52 e30 isn't THAT much faster then my m50 car. If I would have spent $3k+ and only been that fast, I'd be furious...
    Don't get me wrong, if you spend $2k on an m50 swap, no, it's not worth it, and an s52 would be a better value if you can do it for $3k-$4k.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • FredK
      • 14761
      This is true. If you retain the transmission, driveshaft, and diff from the donor car, you can save quite a bit of money.
      I've had both an M50 and an S50US. Both had 1:1 5th E36 transmissions through an S3.46 diff. There is no comparison. 240hp vs. 192hp is a large discrepancy in power.
      • z31maniac
        • 17566
        And TQ, my S52 put down more TQ at 1800rpm then the m20 did at peak at the crank.
        www.gutenparts.com
        • JGood
          • Jan 2004
          • 7959
          I won't argue the low RPM torque of an s52. No doubt it destroys an m50 in that area.
          But I will argue the value of that 20-40whp for $3k+. I've driven an s52 e30, and played with one in my m50 car. Not worth it IMO. Not in comparison to the value of an LS1 or S/C m50, etc...
          Not saying it's a bad engine or anything, as it has great power and isn't overly expensive (especially nowadays, prices are dropping fast). It will walk on an m50 car and is cheaper then an ls1 swap. But for the hp/$, it's just hard for me to swallow.
          • FredK
            • 14761
            That is because you are assuming that an M50 swap costs $-50 and an S52 swap costs $4000.
            If you were to compare apples to apples, and assume the only difference is the cost of the engine, it is $600 vs. $2500. Yes, that is cash. But then again, dropping in an LS1 takes longer than a weekend.
            • Ray Smoodiver
              • Jun 2004
              • 8809
              Euro S50B32 with RMS supercharger
              • JGood
                • Jan 2004
                • 7959
                True. Still, IMO, 3x the price for the power difference is just a bit much for me. I guess if I'm dropping that kind of coin I'd want more then 230hp (which is only obtainable on a full bolt-on s52 with HFM, injectors, tune, etc... which is much more $$$). What does an s50 put down, 200-210?
                • FredK
                  • 14761
                  Yeah, S50US puts down 200 - 210 whp, stock.
                  HFM, injectors, tune = $450 for maybe 10-15 more whp.
                  • JGood
                    • Jan 2004
                    • 7959
                    I wish the hp/$ for these motors was the same as an Ls1
                    • FredK
                      • 14761
                      JGood. A Fox body beckons.
                      • JGood
                        • Jan 2004
                        • 7959
                        Fox body with griggs gr40 suspension and built motor > Any e30.
                        ...awaits ban
                        • FredK
                          • 14761
                          Psh. It's in your blood. Embrace it.
                          As you embrace your sister.
                          • Philo
                            Ich esse kleine Kinder
                            • 3334
                            Hick.
                            Edit: Perfect 1k post. :)
                            -tim
                            Originally posted by Jordan
                            I like the stance
                            • z31maniac
                              • 17566
                              ...awaits ban
                              I also want something with a V8 now.......
                              www.gutenparts.com
                              • FredK
                                • 14761
                                Hilljack.
