What "bolt ons" bring an s52 to 300hp and what's the cost?
  • BimmerTim
    • Oct 2007
    • 613
    #196
    Originally posted by lennon
    can you link to your build thread?
    No need for me to repeat what has already been said numerous times.
    You've done an excellent job of trolling. Don't know the differences in the motor, yet claim to have built one.
    Do you have anything constructive or useful to add to the internet at all?
    And yes, I do know the difference, it was a bit of rhetoric. Also, I never said I built the engine, just the car. It was a 95m3 with a Euro S50B32 swap, with Koala Motorsport euro race diff, moton clubsports, BBS RGRs in 17x8.5 and 17x9.5 w/ Michelin Pilot Sport Cups, GC sways, and Euro 6-speed trans.
    Now you have a small taste of one thing I have done. That was not a hard build in any way, just took time, and money.
    1988 Bronzitbeige Metallic 325e 2-door S50 turbo (OO=( )=OO)
    2008 VW Rabbit
    1991 Audi 200 20vtq Wagon
    • digger
      • Nov 2005
      • 6198
      #197
      if you can get peak power at 9500rpm or so then you will make those numbers. If you are unable to then you will fall short.
        • 34844
        #198
        but hey, that's only 28.4m/s mean piston speed. a mere 3.4ms/s higher than even F1 engines go to. :p
        • BimmerTim
          • Oct 2007
          • 613
          #199
          It's actually only 27.17m/s, but I digress.
          2008 VW Rabbit
          • BimmerTim
            • Oct 2007
            • 613
            #200
            7200rpm is 20.59m/s
            Standard F1 engine at redline(18,000rpm) is 23.86m/s
            2008 VW Rabbit
              • 34844
              #201
              I was using the S52 stroke, you probably used the S50
              • BimmerTim
                • Oct 2007
                • 613
                #202
                True.
                Mostly cuz I have an S50, not an S52.
                Yeah, so the head really only plays a very small part in VE. I found a head that flows way more than enough air, but now looking at the piston speed, I really would be pushing it at 8k, as that would put me at 22.88m/s.
                I think BMW should make their engines more detuned so that we can make more power easier.
                2008 VW Rabbit
                • lifeiskaos
                  • 1709
                  #203
                  that's silly
                    • 34844
                    #204
                    True.
                    while that might be more fun, the ceiling of what an N/A motor of a certain displacement can produce wouldn't change :p
                    8k is doable, the S54 does 7900 with the same stroke as the S52. Of course it also has a far more advanced oiling system and BMW ended up lowering the redline because of bearing issues..
                    • BimmerTim
                      • Oct 2007
                      • 613
                      #205
                      I do plan to dry sump, not that it would change the internal dynamics of the oiling system.
                      8k is totally doable, but not more.
                      2008 VW Rabbit
                      • FredK
                        • 14763
                        #206
                        um, the S54 just has a dual pickup wet sump oil pump. Are there other details that I'm missing?
                        • whiltebeitel
                          • Apr 2007
                          • 2098
                          #207
                          7200rpm is 20.59m/s
                          The max piston speed of a '04 R6, for example, is 79.98 MPH, at 14,000 RPM. 9,500 RPM in a US S50 is 95.47 MPH. A one-race CART engine in (Honda v-12, c. 1992) spins up to 14,400 RPMs with a 47.9mm stroke, making 80.79 MPH max piston speed.
                          What you are suggesting is possible, and has been rumored to be exceeded by a few current race teams, no one is doing it for less than 6 figures, just for the development expenses.
                          Oh, and FYI, 8k in a US S50 is 80.4 MPH, max piston speed. At that speed, the piston should see about 1,953 G's. 400 grams of piston puts ~1,720 lbs of force on the connecting rod. 350 grams would bring that down to ~1,500 lbs of force.
                          '89 325i track sloot
                          '01 530i daily
                          -Enginerd
                          • BimmerTim
                            • Oct 2007
                            • 613
                            #208
                            Yes, I have done all the math, but thank you for posting for others to see.
                            I'm pretty much going to be limited to 8k at the very max.
                            2008 VW Rabbit
                            • whiltebeitel
                              • Apr 2007
                              • 2098
                              #209
                              That math is based on infinite con-rod ratio, btw. Easier to make comparisons witout getting into specific crank specs. Actual maximum acceleration (and thus, forces) will be significantly higer.
                              But that all assumes the head doesn't limit the power. That's where the magics must be!
                              '01 530i daily
                              -Enginerd
                              • BimmerTim
                                • Oct 2007
                                • 613
                                #210
                                I found a magical head, but I think the bottom-end will be the limiting factor.
                                2008 VW Rabbit
