ok..completed a NV M50 swap recently and having hesitation issues..
The car misses and backfires. when the car is cold,it starts and runs fine till its WOT then it misses..when its warmed up,it misses at low rpm's and high rpm's and of course WOT.
I first suspected bad gas, as the car has been sitting for over a year before the swap,so I completely drained the tank.I also installed a new fuel filter TWICE! still runs like ass!,but better
NO codes are found 1444..so i still thought i may have a fuel pressure issue,but it checks out fine.. 46psi @ idle and 53-56 @ all rpms and WOT.
If I am easy on the gas up to almost redline,it feels great,but if Im crusing and punch the gas it hesitates and misses till i back off.
I installed new plugs,2 fuel filters
I suspect MAF, Coil's,dirty injectors,but no codes and never once have i seen the CEL
...any thoughts R3V en's :???:
