im wondering if dirty or leaky injectors are causing the condition,since there was bad gas in tank
I give up...M50 swap rus like ass!
If it idels fine then it's not mechanical. It has to be something electrical. So u can rule out gas and injectors. I suespec timing... Or related to it. Check your cam position sensor and or tps.
Please understand I have NO knowledge on BMW engines but if there anything like te rest it's the same. Giving I know that they don't use map sensors instead the use maf's.Tial, Precision, Garrett Dealer!!!
PM me for more info.Comment
but i have NO Check Engine Light,so I would think if it were a cam/crank sensor the light would at least "blink"If it idels fine then it's not mechanical. It has to be something electrical. So u can rule out gas and injectors. I suespec timing... Or related to it. Check your cam position sensor and or tps.
Please understand I have NO knowledge on BMW engines but if there anything like te rest it's the same. Giving I know that they don't use map sensors instead the use maf's.NASA
BMWCCA member
PCA member 25yrs
1991 318IS slick top
1997 M3 sedan
2001 325CI DD
“whoever turns the wheel the least, wins"Comment
never trust cells! My friend has a 2001 ford with a nasty missfire and it has no cels either.Tial, Precision, Garrett Dealer!!!
Ok came home started car and drove it right away and it runs perfect Cold till near redline. 2 min later starts to sputter in all rpms so only when it starts to warm up it runs like ass. What the hell !!NASA
BMWCCA member
PCA member 25yrs
1997 M3 sedan
2001 325CI DD
Kind of sounds like your o2 sensor is fine until it heats up, causing it to go open. Sending the ECU bad signals
NASA
BMWCCA member
PCA member 25yrs
1997 M3 sedan
2001 325CI DD
NASA
BMWCCA member
PCA member 25yrs
1997 M3 sedan
2001 325CI DD
If it's a cloged cat it would turn red from heat when pressing the gas. Giving the symptoms it's unlikey that's the problem. 02 maybe on bmw's a honda would run on a safe map "limp mode" fine.Tial, Precision, Garrett Dealer!!!
thanks anyway :-)
